I have a newly acquired 185 and am interested in getting the BAS seatbelt/harness system.
It is a landplane but I would like comments on which buckle to get: the standard or utility.
Any comments or thoughts greatly appreciated.
Tom
fishdoc wrote:I've had both styles and prefer the type where the lap and shoulder belts are combined - seems a little more user friendly.
Pinecone wrote:If the airplane may some day be on floats, then the utility. If you're sure that a panick egress isn't likely, then the standard. I'm sure standard is more user friendly. I chose the the utility for underwater egress considerations.
A search will turn up extensive discussions on this topic in the past year, but the above is a good summary.
Rotary buckles were also discussed.
Bigrenna wrote:fishdoc wrote:I've had both styles and prefer the type where the lap and shoulder belts are combined - seems a little more user friendly.
From my standpoint I would say the exact opposite. I found nothing more annoying than when they were attached, especially if you have sewn in loops for the seatbelts. Every time you want to take the seat out you had to unbolt them from the floor and pull the bitter end out of the loop. I sold the standards I had bought in my 170 and went with the utility.
Utility are user friendly and easy. When you get out, just stick em to the velcro discs on the fwd carry thru that come in the kit.
Just my .02
denalipilot wrote:Bigrenna wrote:fishdoc wrote:I've had both styles and prefer the type where the lap and shoulder belts are combined - seems a little more user friendly.
Just my .02
Count me in Greg's camp on this one.
-DP
PapernScissors wrote:CamTom12:
I'm having a bit of trouble visualizing exactly what was zip tied to what. Suppose you could post a pic? Or send me a PM? Thanks
chedrick wrote:I recently put a set in my 182. After a good bit of research and talking to people I decided to go with the utility as the individual belts can be replaced if one is damaged. If you damage one part of the standard buckle you would either half to send the lap belt/shoulder belt out for repair or buy the whole side. Probably not a huge deal but helped with my reasoning. Either way I love the harnesses and they are easy to install (on a 182 with the headliner removed anyways)
