Does any one have any info or opinions about a Bearhawk Aircraft? Looks like a Maule.
Here's there web site http://www.bearhawkaircraft.com/
svanarts wrote:If you like to build, then it's a great plane. You have a brand new plane when you're done for much less money than you could buy a brand new plane of similar capability. However, it is time consuming. I'm about to start building my second airplane because I enjoy the building aspect. I'm also going to be flying a friends plane while I'm building!
highroad wrote:Mark,
Any Bearhawks that you know of that are on big bush wheels and get worked off of gravel bars/rough terrain?
Is the gear designed for big tires (33-35")?
How light can you build one with an 0-540 if you keep equipment/interior minimal?
Thanks,
Brent
wirsig wrote:Won't cost $90,000 if you stick build it. Buy a wire welder, chop saw, and a good 4" angle grinder and have fun while saving money. The biggest advantage I can see for building one vs. buying a maule is if you're the builder you do the servicing, anuals, etc. (saving money) and only carry liability insurance(saving more money). If you bend it you fix it
wirsig wrote:What do you have against using a wire welder?
bmurrish wrote:Tadpole and I both managed to get some stick time in the Bearhawk demo at OSH this past year. Pretty darn incredible bush plane. Got off the ground in no time with 3 of us onboard and had a nice cruise up around 130kts. I did a stall series and the thing just seemed to not want to break. Very docile handling plane. I would have loved to get my hands on the Bearhawk Patrol (2 seat version). If I was going to build one, it would probably be on the top of my list.
wirsig wrote:My build partner and I were curious about that before we started our project so we welded up a couple clusters, locked 'em down in a vice, and proceeded to attempt to destroy 'em. When it was all said and done the welds didn't fail and the tubing was wadded up.
Sorry I got sidetracked from the thread. The bearhawk is a good looking machine. You might also want to look at the widebody super cub.
bcpstudent wrote:wirsig wrote:My build partner and I were curious about that before we started our project so we welded up a couple clusters, locked 'em down in a vice, and proceeded to attempt to destroy 'em. When it was all said and done the welds didn't fail and the tubing was wadded up.
Pre heat and post heat will take care of the cracking when using a wire feed but could you imagine doing that on all of those short welds?
