Backcountry Pilot • Best / affordable / good enough compass?
27 postsPage 2 of 21, 2
Re: Best / affordable / good enough compass?
When the Whiskey runs out or dries up in the desert, the compass still swings. Maybe that is why I mostly used sectional and section lines anyway. Section lines in the desert? Yeah, there are some out there. Look for where the tumble weed snag in the fence lines. Watch out for Spanish Land Grants as they were surveyed on Anglo Saxon 45 degree angles.
This looks nice
skyward II offline
Clamping a magnetic compass to a steel tube...hmmm....
It is hard to find a anywhere on the front of a cub that you will not be close to a steel tube. If you stuck it on the windscreen is the same location the effects of the magnetic fields would be the same the plastic clamp and arm will not effect the compass. The advantage of the Siris is it can be adjusted for the magnetic fields set up by the tubing.
DENNY
DENNY offline
DENNY
DENNY wrote:It is hard to find a anywhere on the front of a cub that you will not be close to a steel tube. If you stuck it on the windscreen is the same location the effects of the magnetic fields would be the same the plastic clamp and arm will not effect the compass. The advantage of the Siris is it can be adjusted for the magnetic fields set up by the tubing.
DENNY
So the SIRS offers better compensation/adjustment for that compared to the more standard ones? That’s a perk
]We had a big vertical card compass that was right in my field of view. The SIRS is much smaller, and it’s so light you can put it anywhere with it’s peel and stick adhesive. Love it.
Compass use story. Somewhat long, ancient news, certainly not backcountry…
You may find it interesting.
JFK-Amsterdam in a Douglas DC-8. About 1/3 across the Atlantic we lost both Inertial Navigation Systems. Pre GPS, so all that’s left is the whiskey compass.
(Unusually, the DC-8 compass is mounted on the cockpit ceiling, aft of the pilots. Each pilot has a movable glare shield mounted mirror, which you angle around to see another mirror on the aft wall of the cockpit, to then see the compass.)
We decided it was safer to go straight ahead. We informed ATC of our condition. Using our dispatch generated flight plan we followed the headings/times. For example, using made up numbers:
50N/40W to 52N/30W
087 degrees for 57 minutes. then
52N/30W to 52N/20W
094 degree for 1 hour 6 minutes
and so on
Finding the UK, we asked the radar controller if they’d been made aware of our situation. “Yes, radar contact, you’re only 10 miles off course, good show”
Words to that effect.
The Inertial Nav system of the day would have had an error tolerance of 3 miles per hour flown, so we beat that.
Traveling the world with 60’s technology was a great time. I’m not being facetious, it was!
aqua offline
aqua offline
