Dokmow wrote:Does the Lycoming Roller Cam help at all? I understand it is still in the same place, but was curious if not having the force of the lifter on the cam helps, or even hurts with the corrosion? I have the same motor, and I do use Camguard.
mtv wrote:There's nothing wrong with Lycoming's camshafts, and your cam with the oil holes may help a LITTLE, but not much.
What kills Lycoming cams is that the engines don't get flown often enough.
The camshaft on a Lycoming is on TOP of the crankshaft, compared to below on a Continental. That position of the cam on the Lyc means that the cam sits up high and dry in a region of the engine which is often pretty moisture laden, after shutdown. So, the cam sits there and corrodes. Till the next time the engine is run.
Hopefully, when the engine is run, the oil temps reach at least 180, and stay there for 20 minutes at least (no ground runs just to "warm it up").
But, nevertheless, the camshaft is up top, sitting in that very moist air trapped in the top of the case.
Now, the cams with the oil holes are supposed to help that. Point is, however, that they sit there, unmoving just like the stock cams do UNLESS you fly the plane regularly. The cams with the oil holes only move oil when running, not when parked.
So, these cams aren't going to help a bit. Save your money and spend it on gas.
Run that engine every chance you get, and you'll not have corrosion problems with a Lycoming cam. Park it for weeks on end and you will, regardless of what cam is in the engine.
Oh, yeah--and add some ASL Camguard every time you change the oil. That is the ONLY snake oil additive that has actually been documented to do something about corrosion.
Green Hornet wrote:mtv wrote:There's nothing wrong with Lycoming's camshafts, and your cam with the oil holes may help a LITTLE, but not much.
I don't dispute your point about engines not flown is the cause of cam shaft issue. Nevertheless Lycoming made an additive lubrication to address this issue specifically which to me indicates they are aware that it is a problem. It is a psychological tactic to tell a buyer that the engine has to be flown once every week or 2 depending on who is using the ploy. Especially if there is an stc that will allow lubrication to get to the area effected quickly on start up. The firewall forward web site has an excellent presentation on the subject. Reality is that some owners just don't have the luxury of flying every week for what ever the reason. We are not all professionals who have to fly to make a living no matter what the circumstances.
What makes sense to me is that if you either have the issue or the opportunity to have the lube holes done then it is one more guard toward preventive maintenance. For the price not to have to have the engine broken down again because you went through one of life's curve balls ( like not be able to fly for some period of time is worth it.) Good intentions often get side tracked.
Besides getting lubrication to the top end of the engine can't be all bad. That is why the use of snake oil hoping it remains there for a period of time not dripping down to the bottom of the engine.
Since I got bit by buying and an aircraft that was claimed to be flown all I can say is caveat emptor. I was tempted to put a preoiler in until I learned that it does not build up enough pressure to go to the top of the engine.
I have no dog in this hunt as far as firewall forward. The question was asked about Cam shafts and I threw this out there for the pilot owner to be aware of the option.
I personally being aware of the issue prefer not to hold my breath every time I can't fly. I have been grounded for 2 weeks going on 3 for an annual waiting for carbon mag brushes. Sh*it happens that prevents routine.
As far as your opinion "that the holes may help a little, but not much" look at the thermal imaging photos.
The bottom line is these are all methods of keeping the cam shaft lubricated. I would rather have a mechanical approach than a " because we have the cam shaft designed at the top of the engine if you don't fly it once a week its your fault if it wears because of friction." That is marketing spin to cover poor Quality Assurance and no design of experiment.
