Best Cockpit Fire Extinguisher?
Fri Mar 14, 2014 12:03 pm
TomD wrote:If I am not mistaken, Halon manufacture was halted somewhere near 2000 and existing extinguishers are using "reclaimed" Halon. I think 1301 is the gaseous version.
The mfg. may have restarted since people like Google, Amazon, Microsoft, etc. have a real need to fight fires in their server farms with something that does not trash the electronics.
TD
Most of these companies are probably using FM-200 for server farms. The tech company I work for uses this and a limited amount of halon for our data centers. CO2 innundation takes a long time, and requires huge cylinders to work in large facilities.
Prosaria offline
269
We still have an older data center that has a Halon fire suppression system, but newer data centers built in the last 15 years are mostly using FM-200 or 3M Sapphire supression systems. The DC I work in uses 3M Sapphire and it is pricy stuff. Halon production was banned in 1994 though reclaimed/recylced Halon is still accessible and existing systems can continue to be used.
scottf offline
650
- FindMeSpot URL: http://share.findmespot.com/shared/face ... cbQCpIqefS
Fri Mar 14, 2014 11:08 pm
6977
The active extinguisher line, very much like fire trace, would be interesting. Protect the whole plane, automatic and discharges at the point of fire wile incipient. We use fire trace at work and it is a good technology.
You can fly the plane while the system works.
soaringhiggy offline
711
48 Stinson 108-3
scottf wrote:We still have an older data center that has a Halon fire suppression system, but newer data centers built in the last 15 years are mostly using FM-200 or 3M Sapphire supression systems. The DC I work in uses 3M Sapphire and it is pricy stuff. Halon production was banned in 1994 though reclaimed/recylced Halon is still accessible and existing systems can continue to be used.
Yes. Unless I've been asleep or lost my mine, Halon has not been manufactured for a very long time. (ozone layer issues) In existing systems, once a discharge has taken place you'll not be able to re-fill without previously stored stock. Alyeska has the world's largest known stocks of the stuff and an accidental discharge is cause for immediate dismissal. The conversion price to FM-200 or Sapphire is not cheap but is usually better than trying to find some for sale and knocking a facility off line while you wait
Did I miss something here? A new Halon branded replacement? (I see now I'm late to the party. Others have brought this up)
Mister701 offline
2134
- Aircraft: Rans S7LS
