Jaerl wrote:In my short time as a pilot I have noticed that 10,20 and 30 degrees are flaps and 40 is air brakes. You can feel the air "buffeting" behind the flaps at 40 degrees. I don't think I have ever flown anything that has enough power to make 40 work well for lift. If I want to do short landings, I always approach with 30 and then hit 40 when I know I'm 100% sure of landing. I do this because a Cessna 150 does not climb well with 40 degrees of flaps.
My friend was landing a 150 at an abandon strip he had used before and some smart ass decided to use 2X4's for the X's on the runway since he was there last. He didn't notice what they were till right before touchdown. He hit the power and did one slow bounce just past the 2X4's. He stayed in ground effect till he had enough speed to reduce the flaps. Then the plane started to climb. Ever since my friend told me this I don't do approaches with 40 degrees.
Jaerl - if your stall speed is reduced with 40 degrees of flaps from what it was at a smaller flap extension, then the flaps
are providing added lift, in addition to the added drag. 40 degrees seems to be a common max flax extension for light aircraft, including Cherokees such as I fly, and the max flap extension provides your aircraft's lowest stall speed.
As for the first poster's (Gflores) problem of hitting your tail cone with 40 degrees of flaps "with power", maybe your issue is you need more down elevator as well as more power to flatten out your short final and round-out to flare. Most light aircraft including C172s will tend to pitch up when adding flaps, and if you're hitting full flaps just over the fence that could be causing the tail-low/pitch up attitude. When you lower the nose to maintain your desired approach airspeed with the addition of flaps, and also keep some power on, that should keep you from hitting your tailfeathers in the dirt, and still let you land on the mains without wheelbarrowing your nosewheel.
