Wed Nov 13, 2019 10:03 am
Not sure what my comments add to this, other than a FWIW sort of thing. When I bought my airplane, it had a pair of Cessna 360 channel navcoms, which were illegal. I replaced both with a pair of Narco slip-ins, as I'd had lots of good experience with Narcos over many years. Of course, Narco bellied up, so I ended up with a pair of orphan radios, but they worked fine, until the nav side of one of them started getting wonky. The avionics shop in Alamosa repaired it, to the tune of about $600.
Then my VOR tracking on both radios really diminished. An avionics shop which is now out of business wanted to replace the "feeler" antenna to the tune of several hundred dollars. My IA said "let me look at it". He unscrewed each feeler, sprayed some contact cleaner on both sides, reinstalled them, and they've been fine ever since--good VOR reception on both radios.
Along the way, I had a new Garmin 430W installed, pretty much the last of the new ones that Garmin sold. It's been a great radio itself, but when it was installed, the avionics shop didn't replace the antennas or cabling for the comm side or the nav side, just added the GPS antenna.
Now here's where the complications arise, and they're just examples of what can happen when relatively simple things start interfering with good communications and navigation reception (you already saw what happens when some corrosion crept in on my nav antenna).
I had intermittent transmitter problems. It sounded fine to me through the headset, but often enough, someone or ATC would say all they were hearing was a carrier. That turned out to be a loose nut behind the mic jack for the passenger side headset--simple fix, but hard to nail down, since most of my flying is solo--had I had a passenger who couldn't trigger the intercom, maybe it would have been easier.
Then, my distance transmitting capability shortened considerably. I first noticed this when Denver Approach handed me off to Colorado Springs Approach, and although I was already over the hill just north of KCOS, ATC couldn't hear me.
Sometime earlier, when I had my ADS-B Out accomplished with a new KT74 transponder, that avionics shop (not the one that installed the 430W) had recommended that I should replace the OEM antennas installed in 1962. I had just spent a bunch, so I put it off. But when I started having the distance transmitting problems, it was time to do something. So I arranged to have them install new quality antennas. In the process, they discovered that the coax from the panel to the antennas was badly cracked in several places, largely because the Cessna installers had bent it too much, and over the years, it just gave way. So they ran new coax to the new antennas--total solution.
But none of that was cheap. It sounds to me as if your partners don't understand the cost of airplane ownership. Yeah, there are a few things that can be done to maintain airplanes inexpensively, but most of the time, it's either spend the money now or spend it later. Like when my IA told me that I needed a new exhaust system, he said that he could repair the old one and it would likely last another year, or he could replace the exhaust system and it would likely last until I quit flying in the future. I opted for the new exhaust system.
The old saying is appropriate here: you can buy good oats, or you can buy oats that have already passed through the horse. Your choice, and your money. There will come a time when the choice is spend the money, or mothball the airplane.
