Wed Jul 20, 2016 10:20 am
The simplest solution to the OP's question:
Buy three Duckbill model 88 ground anchors with the driving rod, sledge hammer, a set of cable cutters, a garden trowel, and 40 feet of 7mm kernmantle nylon rope. At Oshkosh park the airplane wherever they instruct you to, drive in the duckbills to the full 42" and tie the airplane off good and snug on all three points. Make sure you position the tie downs so they pull against each other...in other words, once the airplane is tied down you can't roll it backwards or forwards and loosen the lines. That set up provides approximately 3000 pounds of holding force per anchor, which should be a bit more than adequate if you tied the knots correctly. Chalk the tires. Secure the control surfaces. Keep the doors and windows closed. Stake down your tent and secure the lawn chairs and other items so they don't fly into your airplane when the wind hits. Photograph everything in tip-top shape in case you have to file an insurance claim and this is as secure as you're going to get.
When it's time to leave, dig down six or eight inches around each duckbill anchor and cut the cable off so it doesn't get wrapped up in a mower blade and the cut ends don't impale some barefooted pedestrian. Consider the $50 in lost duckbills a tie down fee.
A quick note on liability: I don't know what the norm is for insurance claims, but I know of at least one case where an uninsured airplane broke free from inadequate tie downs and struck a neighboring airplane. The uninsured owner claimed it was an "act of god" and therefore not his fault. He got sued and lost, and had to pay damages for his neighbors airplane out of pocket. Oh, and his airplane was totaled. Good things happening to good people, but that's a different story.
As for tie-down theory:
I agree that less angle of attack is better, but putting the tail up on a tripod or saw horse? No thanks!!!!!!
Something professionally engineered, tested, and fabricated for a specific airframe could certainly work, but lifting the tail up onto a improvised stand and tying it off to some ground stakes strikes me as infinitely more dangerous than just accepting the high angle of attack, regardless of wind speed or direction. I don't think you can adequately secure the tail to the stand or the stand to the ground, and when the tail comes off the stand or the stand breaks it could easily go through the tail feathers, AND the tail will no longer be secured.
For the bushwheel crowd a much simpler solution is the let most the air out of the tires. Ya...doesn't look cool, but it does reduce the angle of attack...
Another solution (probably not acceptable at Oshkosh) is to dig a couple holes for the main gear and push the tires in. This not only reduces the angle of attack without the complications and additional risks of lifting the tail, but it acts as super-chalks. Anyone trying this needs to ensure that a whole lot of manpower is available when it comes time to leave, as getting the airplane out of the holes is surprisingly difficult.
And at the end of the day, if you're dealing with wind strong enough to damage the airframe and you're not tied to permanent in-ground anchors, it's unlikely your airplane is going to stay put. It's certainly possible to rig field anchors that will hold the airplane in any amount of wind, and if I was going to be at Oshkosh for two weeks I suppose I'd take the time and expense to rig them, but it's not the norm. And even then your airplane is just going to act as a collection point for all the other airplanes, tents, chairs, kiosks, EzUp sun shades and small children that are tumbling across the field if the wind gets that strong.
As for gust locks...I secure my rudder and my elevator with the same external device. It ends up being full stick-forward...that's just how the device holds it, and it works fine.
I understand the inherent visibility difference of internal vs. external gust locks, but I don't subscribe to that line of thought. Like the admonishment about never turning the fuel selector to "Off" because you might forget to switch it "On" before take off, there's some logic in it, but not enough (to me) to warrant the procedure. "Controls free and correct" is a foolproof two-second part of the pre-takeoff check, just like "fuel on both".
If you chase down and eliminate every potential pitfall then you just have to quit flying. If not using external gust locks works for you then that's fine and I don't think it's wrong, but I don't feel they are inherently unsafe.
