BH Companion Build
Today was a milestone, bolted the wings on
Utah-Jay offline
367
- Aircraft: Bearhawk Companion
I was going back through your pictures and noticed the cross-over exhaust. This is a really nice setup. It should add power to your O-360 since that engine fires both cylinders on one side of the block and then both cylinders on the other side. In straight exhaust systems that means two exhaust pulses chase each other down to the muffler. With the cross-over, back pressure in the exhaust is reduced because the second exhaust pulse goes to the other muffler. I LIKE IT! Was this system made by Custom Aircraft Parts in El Cahon?
1002
- Aircraft: MX7-180C
Looking just about ready to go. You must be chomping at the bit. Beautiful.
I had a Bearhawk Patrol 90% complete lined up to buy a week ago and got a text at 5:00 AM on buy day that seller changed his mind. I nearly cried…….
skyward II offline
480
Flyhound wrote:I was going back through your pictures and noticed the cross-over exhaust. This is a really nice setup. It should add power to your O-360 since that engine fires both cylinders on one side of the block and then both cylinders on the other side. In straight exhaust systems that means two exhaust pulses chase each other down to the muffler. With the cross-over, back pressure in the exhaust is reduced because the second exhaust pulse goes to the other muffler. I LIKE IT! Was this system made by Custom Aircraft Parts in El Cahon?
Thanks
The exhaust is a Vertterman. It is supposed to create an additional 10HP
Utah-Jay offline
367
skyward II wrote:Looking just about ready to go. You must be chomping at the bit. Beautiful.
OUCH!
I can’t imagine how you felt.
I have a bit to do yet, but getting there
Utah-Jay offline
367
