WWhunter wrote:Tom,
Other than the HACman fuel leaner, did you change anything in the carb after the Zipper mod? Mine has gone from 80HP to 95 (?) to 105HP with the same kit as you. Just got back home after my winter solstice and my engine is not runing correctly. Had to replace the voltage regulator/rectifier also. Removed the plugs and they are very black, ie. running rich. I think this engine is going to be the one that drives me NUTS (nuttier than I already am).
Sure I fly a lot but it's all local, maybe an hour out somewhere, and an hour back. Plus with doing a lot of fooling around on the way, getting any kind of handle on my fuel burn was mostly guess work.
Mission accomplished, using the Leaner, turning that big Prince prop slowly, not being in a hurry ( the GPS showed 80's mostly, with some 90's, no wind to speak of) really paid off. Oh yeah, after that 7.2 hrs airborne, I still had an estimated (using the fuel burn of 2.7 GPH and the remaining fuel onboard of 15 gallons) 5 hrs of cruise with 40 minutes reserve. In fact it turns out I could have made it home (which I did, later that day,another 3 hrs) without the Emmett stop! I was amazed, I was hoping for 3.2 or so at best, I keep looking for errors but can't find any. Having a fuel flow indicator was critical, as it showed how almost no changes in airspeed gave large fuel savings. A little faster took more fuel then it was worth. Though coming back into my place, I saw a big cell right over "my" mountain range, the only WX all day and it's right over my strip looking to go critical any minute. I texted a neighbor when I was 8 miles out and he kept me informed, running into a gust front on the wrong side of the 9K+ ridge I'm below is not good, done it once. So pretty much firewalled it and got it down and in the hangar 15 minutes before the storm hit, which I watched from the deck with a cold beer
courierguy wrote:It wasn't until I finally got the right Prince prop that my BB really got dialed in. Though it was still a major improvement with a re-tweaked Kiev, the Prince really made a huge difference. I'm not saying you need a Prince specifically, just that I'm not surprised you are experiencing some issues, especially as you went bigger bore then I did![]()
I just flew to S. Dakota and back (13+ hrs @ 3.85 gph of regular mogas) and Mr. BigBore Hal was there also (and flew even further of course, coming from Elko, I think he won the "furthest flown" award if there was one). At one point we went out and were screwing around on a nearby lake doing some island landings, then on the shoreline. On short notice and without any forethought, while we were both back taxiing for takeoff, I asked Hal if he wanted to drag race. He of course was up for that, so PA-12 pilot Pete, who was already in the air, did the count down. I think Hal's plane was unloaded, I still had my 30 lb. bike on board, and I may have 10 or 15 lbs on him, plus heavier gear and tires, but I got off sooner and appeared to be holding the lead in climb, though we broke it off pretty much after we got to 200' as the intent was to see who got off first.
He has the hi-comp mod, so for sure more power then me, and while we both know our planes inside and out, I think this drag race really showed what the right prop, in my case the 78" Prince, can do. It was a win/win for me, if I would have lost I could have blamed my engine and the guy who came up with the mod, if I won, I won! Great fun, we had a blast.
