http://www.idahostatesman.com/newsupdat ... 36569.html
C ya, Bub
a64pilot wrote:I've got quite a bit of Mooney time. A Mooney will float more than anything else I've ever flown. That long wing get's into ground effect and floats forever. To get one in short you have to nail the speed on long final. They are also slick as snot and won't slow down worth a darn. They are fast because they are slick, not because of high power. The older little Mooney's like this one won't climb worth a darn either. Wonderful little efficient, strong airplanes as long as your friendly with whom your flying with, but I just about can't think of a poorer choice for a back country airplane.
a64pilot wrote:A Mooney slips well with flaps as far as I remember. The speed brakes are way cool, instant 500 FPM descent and no trim change. Mooney flaps are not nearly as effective as say the Fowlers on a Cessna and VFE if I remember right is 112 kts and VLE 132, so you get gear first which is backwards so to speak.
iceman wrote:This really blows my mind. I always thought, and still do that JC and Big Creek and Moose are probably the easiest strips up there. Big Creek has an approach as long as you want to make it depending on when you turn back upstream. It is a straight in approach and an uphill rollout. I've touched down at mid field and coasted to a stop with no brakes. I also find it hard to believe you can't slow a mooney down enough to safely land in 2000 feet. I'm certainly not one to talk when it comes to screwing up a landing but If you can't put it down slow enough and at least somewhere before mid field you have no business in the mountains.THere have been twins into Big Creek!
