The main runway is about 2300ft long at about 5000 MSL. It still has a little water on it as of 4/24/19 but should be dry in a week or two. I landed on the shorter runway 28 that has an uphill slope and better drainage. Runway 28 is pretty rough for 800X6's and has an uphill slope It would not be hard to get stuck without bigger tires so keep your speed up until you get to the runway intersection where it smooths out. I would not use this runway again without a good reason.
The main runway is relatively flat and smooth. 600X6's should be OK if rough field techniques are used. The approaches are clear from both directions. 16-34 has tires marking the ends but they could use a new coat of white paint. There is an ATV trail that crosses the runway but it doesn't cause a problem. There is a hole in runway 34 near the ATV trail crossing on the left edge.
There are reasonable camping areas near the the runway intersection. A wind sock pole is located at runway intersection but the sock is gone.
You can watch a YouTube video showing a low pass and landing that some fine person posted.
Fly safe. Marc
