contactflying wrote:...
I have never used sunglasses or visor, including military, that works as well as my fist to block dangerous sun angle. Hold your fist up in the windscreen and look around it. Tiring, but it always works well.
G44 wrote:Make sure you NEVEAR clean a windshield using a swirl motion like most people do, this leaves little micro circular scratches that appear big time when you fly into the sun. Make vertical strokes when cleaning the windshield. Make sure all dust and dirt are rinsed off with water first before spraying your favorite cleaner on. Spraying cleaner on a windshield with dust or dirt then wiping only cuts small scratches into the plastic from the grit and abrasion of the dust or dirt. Remember, vertical motions and not swirl motions. This will go a long way in helping with the sun.
gbflyer wrote:G44 wrote:Make sure you NEVEAR clean a windshield using a swirl motion like most people do, this leaves little micro circular scratches that appear big time when you fly into the sun. Make vertical strokes when cleaning the windshield. Make sure all dust and dirt are rinsed off with water first before spraying your favorite cleaner on. Spraying cleaner on a windshield with dust or dirt then wiping only cuts small scratches into the plastic from the grit and abrasion of the dust or dirt. Remember, vertical motions and not swirl motions. This will go a long way in helping with the sun.
That’s a good tip!
