Sat Jan 08, 2005 12:17 am
I use BLM lands a lot (helicopter on trailer behind full-time RV). In general, the agency does not care if you operate aircraft off their lands in NV UT AZ NM OR. Being federal, the CA lands are likely to be no different.
I cannot make a claim to have tested this in CA. I have yet to get a clear answer from CA offices, because I tend to avoid CA in general. When I did go in to the Imperial Valley office to ask, I got a very hostile response from the regional manager, who believed without being able to cite a regulation that aircraft were generally prohibited. He would not help find such a regulation, and became openly confrontational when asked for the citation. And as you know, it's real hard to prove a negative, so I don't have a way to look for the LACK of a regulation.
Other BLM offices (notably Yuma, AZ) tell me this guy is famous for knee-jerk regulatory inventions like this. But I gave up on CA, having lots of other fun things to do.
Note that BLM sometimes passes internal regulations prohibiting aircraft, notably in the new National Monuments of UT, some of the first such federal areas administered by BLM instead of NPS (who universally prohibit aircraft without any relief whatsoever). BLM does that by generating a Resource Management document and specifying no aircraft on that particular Nat'l Monument. Exit much of BLM/UT as aircraft operating area, effective on various dates 2003-2004. (But BLM's Canyon Rim Recreation Area out by Moab is WIDE OPEN, they don't care a hoot!)
Capricious enforcement of federal regulations is rampant. Example: the Code of Federal Regulations Ch 48 (?) specifically allows aircraft to land at Cottonwood Airstrip on the (AZ) shore of Lake Mojave. But the Chief Pilot for Lake Mead Nat'l Recreation Area, a redneck kneejerk anti-freedom type, considers it his duty to arrest anybody landing on the strip because they have closed it. Without changing the federal regulation specifying that it is a usable airport.
As we say in paragliding & soaring, 'tis more blessed to beg forgiveness than to ask permission. And in MOST cases nobody will even know you're landing in areas they consider off limits. But there ARE aerial patrols daily in many heavy-public-use jurisdictions, not to mention TSA satellite monitoring. And finding out whether it's OK is a recurring pain in the butt when I'm actually out there operating.
Suggestion: find out which regional office controls the areas you're interested in. Network around in their phone directory until you find their chief pilot. HE does the aerial enforcement patrols; HE will be able to tell you what's OK.
Let me know your findings, I'd like to figure out CA also.
Dave
masmesa @ aol . com
