Bombs away!
BRD sent me this cool video of his ride along for a Fish and Game stocking op.
http://www.backcountrypilot.org/videos/slow%20fish.mov
I don't understand how they're not killed by the shock of impact? Tough little suckers. I love the vantage point.
2855
There was an article about just that not long ago. I think it was in Plane and Pilot.
Not enough mass to create high impact forces, I'll bet. You suppose they dive in the pike position or just flounder their way down?
GroundLooper offline
1168
BCP Poser.
They found when they first did this that they had to increase the height enough so that the forward speed bled off. the drop didn't seem to bother the little buggers but skipping them across the surface of the water did.
shorton offline
662
- Aircraft: Stinson 108-2
To add to that, dropping from 100-150 feet also allows the fish to stop tumbling and streamline before hitting the water headfirst. As Shane points out, smacking the water on their sides had deleterious effects...
Dropping in the cold water of the Spring and Fall also helps their survival rate.
(mucho' great fun all around! and yes 'looper, I got it...)
1451
Mon Nov 03, 2008 10:16 pm
Something wrong on my end, I can not view the video
5297
Mon Nov 03, 2008 11:15 pm
58Skylane wrote:Something wrong on my end, I can not view the video
It's a Quicktime (mov) movie file format, which is not supported by Windows by default. You either 1) have to install Quicktime for Windows from Apple, OR 2) install this (which I recommend...it plays everything):
http://www.videolan.org/vlc/
2855
The latest Real Player version also handles .mov files
1451
Tue Nov 04, 2008 11:19 am
GroundLooper wrote:There was an article about just that not long ago. I think it was in Plane and Pilot.
I think you are right it depends a lot on where the airplane is perched.
skybobb offline
634
My back country videos are here:
http://www.youtube.com/skybobb"I don't belong to any organized Political party, I'm a Democrat."
Will Rogers 1879 - 1935
Tue Nov 04, 2008 11:33 am
1451
BRD wrote:To add to that, dropping from 100-150 feet also allows the fish to stop tumbling and streamline before hitting the water headfirst. As Shane points out, smacking the water on their sides had deleterious effects...
Makes em all walleyed!
1168
BCP Poser.
I think it takes a special pilot to do these drops. Some pilots just don't give a carp!
skybobb offline
634
Flounders don't fly right, they go like a frizbee and skip over the water!!!!!
shorton offline
662
Poor pilots kill a lot of these fish because their flying technique is so crappie.
skybobb offline
634
When you watch from the ground and they are dumping them into the water, if the light hits the mist of water trailing behind the plane just right you can see the rainbow.
1736
Some of them hit the water head first, it is a good thing that, I swear they act like they have steelheads.
skybobb offline
634
I've heard the ones that get "tore up" in the slip stream end up as cutthroats///
Of course if you drop them off from too high with all the broken bones they just turn to jellyfish
Rob offline
1569
I think some of these pilots fly to low and that is not good. You can explain it to them but they are just too bullhead ed.
skybobb offline
634
You all are a bunch of Suckers for continueing this.
2036
- Aircraft: RANS S-7
I think they would land on their feet if they were only cat fish.
skybobb offline
634
I think that pilots that do this type of backcountry flying, especially in and out of these small lakes, have bass balls!
Skystrider offline
1232
- Aircraft: Zenith CH701 w/ Jabiru 3300
