Backcountry Pilot • Bonanza, Piper Lance, C210, Or???
79 postsPage 2 of 41, 2, 3, 4
Re: Bonanza, Piper Lance, C210, Or???
lowflybye wrote:
mr scout wrote:
Blu wrote:I have gone on fly outs with strutless 210 and the cirrus will out climb them and out cruise them and burn less fuel doing it.
Sure, put 310 ponies under the hood of 3400 lb takeoff and it will out climb a 285 hp with the same MGTOW any day. Equal the HP and see how well they compete...plus the 210 can do it with 2 extra people on board. The Cirrus will not burn less fuel at the same speed nor outrun a 210 at equal HP ratings nor does it have the load or range of the 210. To get 310 hp in a 210 it would be a turbo model and will cruise in the mid 190 kt range as opposed to the 310 hp SR22 which will cruise in the mid 180 range. Just like with comparing a 210 to a Bonanza you must compare the same HP. The 210 has a very wide range of HP options available in the different years.
I have to disagree with you on this. The cirrus is a slicker air frame than the 210. Take a turbo 210 and compare it to a turbo cirrus. Both have 310 horse power but the cirrus will be 15-20 knots faster at any given altutude. The 210 I flew with only had 285 horses but he was running 75% power (213 HP) and burning 15-16 gallons per hour while i was running 65% power (201 HP) and burning 12.5 gallons per hour and I was still 5-7 knots faster.
I agree that horse power probably explains most of the climb differance
Blu wrote:Your pocket book will thank you at annual time too.
Don't forget to mention that $10,000 CAPS re-pack that currently must be done every 10 years. If you have a 2001 model you are on the short list.
Good Point!! :(
Blu offline
mtv wrote:
If twas me, I'd look for a solid 210 with a turbo. Don't be scared by the gear--find a mechanic who understands the gear and knows how to make it work. It's really reliable. With one exception: If it still has gear doors, get rid of them. A large percentage of the gear problems on these airplanes were caused by the gear doors. There is an stc to remove them, and later airplanes didn't have them.
As Mike has said...get the INST rating...it may be the difference in insurability or not on any of these aircraft and will definitely make a difference in premium. Currently the Cirrus premiums are comparable to the other 3 models listed due to the rash of losses.
With regard to the 210 gear...the doors are not the problem, but proper maintenance is. Unlike most light aircraft, the 210 gear system is fairly complex with sequential switches and such in the hydraulic system and resembles the gear of more advanced aircraft. The earlier models had a manual lever to the hydraulic pump in the cabin while later models had an electrical lever that activated the hydraulic system. If the mechanic is not familiar with the system it will cause you problems. I have over 300 hours in various 210 models both with and without the Uvalde gear door mod and I have had failures in both styles. Now, let me caveat that by saying I have not yet had to land one gear up. The gear system although fairly complex is pretty simple to troubleshoot and keeping a level head while troubleshooting usually results in a quick fix and normal landing with the gear down and locked.
The trouble with removing the gear doors is that the main gear buckets are not sealed as the doors were designed to take care of that. As such, when in slow flight or higher AOA flight as in the pattern or climb-out, the exhaust enters the main gear buckets and carbon monoxide can become a problem in the cabin if flown in this configuration for extended periods. If the gear doors have been removed you should ensure that the buckets were sealed when the mod was done...this is rarely the case.
I have time in the 210, Bonanza, Cirrus and Saratoga...for my money I would take the 210...hands down.
lowflybye offline
A friend and his father are rebuilding an F33A Bonanza down in Provo. A hapless pilot crashed it on landing in Missouri, he never disconnected the autopilot.
They invited me down to see their progress. They had the belly skins and some side skins removed for replacement. Even knowing that Bonaza's are built well didn't prepare me for what I saw inside that plane plane in terms of structure, strength and build quality. The landing gear is essentially that of a ton-heavier Duke. Its a mini KingAir. No Cessna piano-hinges on flight controls anywheres. They aren't built like other small planes, period.
My Piper, love it though I may, is an absolute Beer can next to a Bonanza. Not fit to shine its spinner #-o Now I just need Bonanza income!
Think A36 and straight-tail 182 in the garage Pat. Now your livin'.
My .02
Blu wrote:The 210 I flew with only had 285 horses but he was running 75% power (213 HP) and burning 15-16 gallons per hour while i was running 65% power (201 HP) and burning 12.5 gallons per hour and I was still 5-7 knots faster.
The difference in this case (I would assume) is that he did not have GAMIjectors or an engine monitor and you have both which would explain the fuel difference. We have both in our 210 and routinely run 50 LOP and match the fuel burn you are claiming while clipping along at around 150 - 155 kts. I can run 50 ROP and burn around 16 gph and cruise at 160 - 165 kts.
No argument that the Cirrus is a fast airplane and I am not knocking it, but they are completely different aircraft built for completely different missions. I like the Cirrus and fly them along with the others when the mission fits it's profile. Having said that, I have not flown any other aircraft that I prefer over the 210 for hauling a large load at a fast speed while sitting very comfortably on an X/C flight...and the 210 is a very stable IFR platform.
lowflybye offline
Blu wrote:Take a turbo 210 and compare it to a turbo cirrus. Both have 310 horse power but the cirrus will be 15-20 knots faster at any given altitude.
Actually Blu, the Cirrus TAT (which is slightly faster than the factory turbo) has 315 hp and trues out right at 195 kts cruise at 16,000. The T210 can have 285 hp and true out around 190 kts in cruise, 310 hp and true out at 195 kts in cruise, or it may have 325 hp (R model) and true out at about 205 kts cruise.
As I said before...hard to compare these two because there are so many different variables.
lowflybye offline
lowflybye wrote:The difference in this case (I would assume) is that he did not have GAMIjectors or an engine monitor and you have both which would explain the fuel difference. We have both in our 210 and routinely run 50 LOP and match the fuel burn you are claiming while clipping along at around 150 - 155 kts. I can run 50 ROP and burn around 16 gph and cruise at 160 - 165 kts.
That sounds about right. I get 170-172 kts on 12.5-12.9 gallons per hour running 50 LOP and he was running ROP. But i still think that proves my point that the cirrus is a slicker airframe than a 210.
Not saying 210's are not good planes but for the original posters mission: flying four people from VCV to BOI the cirrus has a lot to offer.
It can comfortable make the trip with four people and bags. It will get there faster and on less fuel than a 210 and for a given amount of money he could have a newer plane with better avionics.
Now if he had said he needed to fly 5-6 people with bags then i think the 210 would be like the right plane. (although i feel like 5th and 6th passanger in a 210 get the short end of the comfort stick)
Blu offline
I agree that the Cirrus appears to be a slicker airframe, but gear hanging down in the slipstream cause a lot of drag. The only way to know for sure would be to have a drag co-efficient comparison on the two aircraft, but since we cannot do that we can compare performance at a given HP. With equal HP the Cirrus should walk off and leave the 210 if it was indeed a slicker airframe and the fact is that it does not do so which means that it is not more drag efficient. Compared to other fixed gear aircraft this is the case...for instance comparing it to a C-206. There is no substitute for removing drag completely as in retracting the gear.
lowflybye offline
lowflybye wrote:Actually Blu, the Cirrus TAT (which is slightly faster than the factory turbo) has 315 hp and trues out right at 195 kts cruise at 16,000. The T210 can have 285 hp and true out around 190 kts in cruise, 310 hp and true out at 195 kts in cruise, or it may have 325 hp (R model) and true out at about 205 kts cruise.
Interesting numbers, are you going off experiance or off cessna's book numbers?
My experiance with cessnas book numbers is that they represent wishful thinking from the marketing department :^o And are almost never achived in real life. Well except the fuel flow numbers i always seemed to get all the fuel burn they said i would. :P
Conversley I have found the book numbers for my cirrus to be right on or even a little conservative.
But like you say it is hard to get fair apples to apples test.
Blu offline
Blu wrote:Interesting numbers, are you going off experiance or off cessna's book numbers?
My experience with cessnas book numbers is that they represent wishful thinking from the marketing department :^o And are almost never achieved in real life. Well except the fuel flow numbers i always seemed to get all the fuel burn they said i would. :P
The numbers in the 285 and 310 models are from experience. I have not flown the 325 hp model and pulled it from the Blue Book Price Digest performance charts. Keep in mind that these speeds are in aircraft with the gear doors still on the aircraft. Often times pilots will fly the 210 with a gear mod and wonder why they are not making the book numbers. The gear mod does cost you a some speed.
As I said, I like the Cirrus and think it's a great aircraft. I fly one on occasion when I just need 2 or 3 seats, but I usually need more seats and/or baggage so for my mission the 210 usually fills the bill a bit better.
lowflybye offline
lowflybye wrote:The numbers in the 285 and 310 models are from experience. I have not flown the 325 hp model and pulled it from the Blue Book Price Digest performance charts. Keep in mind that these speeds are in aircraft with the gear doors still on the aircraft. Often times pilots will fly the 210 with a gear mod and wonder why they are not making the book numbers. The gear mod does cost you a some speed.
Well judging by those numbers then i stand corrected. I would appear that the drag on the airframes must be pretty close to the same depending on the model year.
No doubt the 210 is a better load hauler, although my cirrus with a 1153 lbs useful load is not to bad and as i said in my original post might suit the original posters mission well.
Blu offline
58Skylane....
......I've got lots of time in the Bonanza and in my opnion it is still just the finest single engine, recip out there. Now I never thought of it as a real back country airplane but obviously it does fine in other than the more challenging situations. Someone mentioned a Cirrus...yeah they go fast but personally I'd rather have a 30 year old Bonanza than a brand new Cirrus. My buddy has a 2008 Cirrus....not only has it's value dropped by nearly 50% but he has constant problems with all the gee- whizz stuff in the cockpit. Nothing but trouble. The damned computers are a pain in the butt. He likes technology but is so frustrated that he said last week ....."I'd dump everything for a good set of analog gauges."
As for the T-Tailed Lance....if you gave me one: I'd sell it without ever leaving the ground. They are ground lovin sons of a guns and have rather limited C.G. range. The charity for which I fly as a volunteer pilot had one donated about 18 months ago. I ferried it home. To say the least I was not impressed. The charity got all excited and decided that they would replace our workhorse C-206 with the Lance. There was a collective groan among the pilots....but the boss was sold on the Lance.
So....after an engine overhaul and getting everything in tip top shape the shakedown flights began. Before we ever put it in service it was discovered that with 2 pilots and full fuel tanks it was out of C.G!?! The take off performance was so poor at gross wt. that our organization restricted the aircraft to runways of 5,000 ft. or greater. Now that was a bit of overkill , I will admit,but policy non-the-less. After a few flights the limitations became even more obvious.
Common sense finally prevailed....the C-206 was reinstated and rejoined our two Senaca. The Lance was sold. Don't see how anyone could compare the T-Tail Lance favorably with a Bonanza. But hey....my wife is crazy about me....some women would puke at the very thought! :shock: To each his own.
Bob
z3skybolt offline
Living the Dream
once&futr_alaskaflyer wrote:Hey Bonanza Man are there STOL mods for the Bonanza, besides VGs?
There was a kit to make the ailerons extend with the flaps but only a handful were ever made. I have the VG's on mine.
Bonanza Man offline
Ok, I have been thinking on the cirrus- 210 issue.
Since I don't have a turbo'd plane I'd like to look at NA planes for comparison. The numbers I posted for my cirrus in still air making the trip from VCV to BOI are very accurate and if anything high.
VCV-BOI in 3:13 burning 43 gallons carrying 820lbs of payload with a 1 hour reserve. Does anyone have a accurate flight planning model for a NA 210? What kind of time fuel burn can a NA 210 do on the same trip? Also what can a BO do the same trip in? Be interested to compare.
Also be interested in what kind of payload the 210 and BO can haul on the same trip with a 1 hour reserve.
Blu offline
58Skylane wrote:Thanks for the info so far guys!!
I should mention that this will be a commuter plane between Boise/southwest Idaho and SoCal. If this deal goes through (and this may be a long process. Long story to get into at this point), I'll more than likely commute as little as once a month to every other week (depending on the budget). I'm not IFR rated now, but I won't rule that out later (if that time comes). Personally, I don't really care to fly into IFR/Known Icing in a single engine aircraft. I'm pretty sure my schedule will be very flexible to avoid any crappy weather flying. But, doesn't hurt to be prepared.
I would plan to keep my 182 in Idaho for backcountry flying. Or since my income may triple [-o< , I may even be able to afford to get a Scout along with the commuter plane.
The reason why I asked about landing on gravel/dirt, is that the business my brother in law may try to acquire is in the desert and has a gravel strip about a mile down the road. Or may be able to use part of a dry lake adjacent to the business when it's "DRY".
I really dig the 210's. But after reading the comments about the gear, I may want to shy away from that model.
After chattin with Mr Scout today, I'm really digging the Commander. I like the idea of the "Spring Loaded Gear" in case of gear extension problems. But not really the speed I would want. I really would want to keep the commute under 3 hours if at all possible (on a good/fair day).
My airliner friend Joe has a straight tail Lance and I feel very comfy in it and happy with it performance. So, so far the Lance and Bonanza is going head to head here.
I don't know much about go-fast ones, 'cept for a '59 250 Comanche that we used to own. Fine x/c machine, 150kts all day long.
What I really want to know, is what the hell are you going to be hauling out of the desert that pays so well? :D
gb
gbflyer offline
Ok, here is my $.02. I owned a T-210 from '90 till March '04 when a damn Mexican stole it from me. If I still had it and could put it on floats, I would be a happy camper. A very good friend of mine had a '78 T-210 and was asked to fly a friend's A 36 while the guy was working out of the country. My buddy hated the Bonanza, period. I know that Beech owners are a very loyal and passionate group. I just know what I hauled in my 210 and still was fast. I can't believe that a Beech could equal the combination of speed, load, and affordability. I acknowledge that a Bonanza might be a TAD faster, but not with a huge load, cg problems arise quickly in a Beech, I think! :P
I have owned a 182, 206, T-210, and a 185, and have about 2,000 hrs in the 210. For ME, the 210 was light years ahead of any of the others. Faster by almost 50 kts, can carry as much as the 206 ( a little harder to load), and much easier on the ground than the 185(and wider). IF you just want to go from one point to the other, I guess the Cirrus would be good. I can't believe you can find a better plane for the $$ than a 210. I had the gear doors and John Frank told me when I asked about removing the gear doors, "don't do it". Just make sure you lower the gear doors Below gear extension speed. He was right. If you want to haul a load, go fast, and have reasonable (for a plane) parts, a Cessna is for you. Composite materials, glass panels are all great IF you have the money, I don't. When I stop flying floats, I pray that I have enough money and life left to go back to a T-210!
FloatFlyer offline
Blu wrote:Ok, I have been thinking on the cirrus- 210 issue.
In our 74 model with with NA 285hp I typically plan for 150 kts LOP burning slightly over 12 gph which would make trip 3.6 hours and burn 43 gallons. We have a STOL kit on ours which slows us down about 3 kts due to the leading edge cuff, but we can maintain the climb rate on a hot day and at higher altitudes. If I figure 43 gallons plus 1 hour reserve of an additional 13 gallons at 7 ppg that gives me a fuel load of 392 lbs. With a MGTOW of 3,400 lbs and an empty weight right at 2,000 lbs that leaves me with 1,400 lbs useful. Take out the previously mentioned fuel load and I have right at 1,000 lbs payload.
Our 210 has 90 gallon tanks so the range can be nearly double what is needed for this trip while maintaining a useful load of right at 800 lbs. The general rule in a 210 is if you can load it and close the door it will fly it...if you have to force the door shut just add 500 ft to the takeoff roll and it will still fly it. :D
In this scenario you have me beat by about 15 minutes on a 540 mile trip, but I still maintain the higher payload and am only 285 hp. if I increased the fuel burn a bit i could match your speed and time in route but I would burn about 10 more gallons on this trip. The 300 hp will go a bit faster, but will burn a bit more fuel. I would bet that comparison will be pretty well even on time and the payload will remain pretty much unchanged.
lowflybye offline
gbflyer wrote:
gb
Because the business transaction has not even started at this moment, all I can tell you is that it involves very profitable mining. It's a deal that will more than likely go through. But it may take some time.
On another note and to throw a little twist on things here. My brother-in-law just told me that I should consider a Lancair 4. He has a couple of customers that have them. One is a dentist that commutes between Phoenix and Fullerton, Ca. Say's he can make the trip in just over an hour each way :shock:
But, very good info by all again. Even though I may not purchase anything any time soon (heck, I'm still saving up for a new engine for my 182), I really do appreciate the time and effort you all are putting into this thread! Great reading and a better understanding of the different models mentioned for the said mission.
MTV and others are right about getting the IFR ticket. Unfortunately, my 182 is basic VFR equipped. And I'm not going to upgrade it anytime soon are get the rating anytime soon. I'm having a hard time coming up with the money for the engine as it is. So getting my IFR would have to wait and will more than likely get it if the time comes.
Or??
There is a Helio Courier on Barnstormers.com ;)
FloatFlyer wrote:Ok, here is my $.02. I owned a T-210 from '90 till March '04 when a damn Mexican stole it from me. If I still had it and could put it on floats, I would be a happy camper. A very good friend of mine had a '78 T-210 and was asked to fly a friend's A 36 while the guy was working out of the country. My buddy hated the Bonanza, period. I know that Beech owners are a very loyal and passionate group. I just know what I hauled in my 210 and still was fast. I can't believe that a Beech could equal the combination of speed, load, and affordability. I acknowledge that a Bonanza might be a TAD faster, but not with a huge load, cg problems arise quickly in a Beech, I think! :P
With the same engine the Bo and 210 should be very close in speeds. I have the IO-520 at 285 HP and get 172 kts true, which is about 5 knots below book as I have VG's. The useful load is a little over 1300 pounds. Not sure what the similar 210's can haul as I have no interest in them. CG problems are way overstated. With full tanks I am near the forward limit. The A36 has no CG problems at all, with the 35's you have to understand the issues and watch it. The A36 is heavier and can't get off the ground as fast as a 35, it's also slower for the same reason.
Bonanza Man offline
Ok stop before someone tells Pat he just need a Maule..........This thread is like asking what girl to pick at Mina :lol:
Pat what you really need is a T-6 our slow one goes 215. And they are in your price range. When your ready come down for a ride but be warned once you get behind a round motor you will want to take it home with you.
You wont need to buy another airplane until the hot chick you pick up in the T-6 decides its time for a family. :shock: =D>
mr scout offline
