Backcountry Pilot • Broken easy out on exhaust flange!
6 postsPage 1 of 1
I did it. Tried using a stud extractor on an exhaust stud and it twisted off. OK on to plan B and cut it off flat, drill into and and use an easy out screw extractor. Snapped it off real easy up inside the hole... In panic mode thinking I would have to pull the cylinder I went google searching for Plan C.
Plan C turned out to be a tool called Rescue Bit. I am not affiliated in any way but I can report that this tool allowed me to turn that easy out into dust and I may have been able to use existing threads as I did not have to open up the hole too large. I chose to drill it out to 17/64 and install a Heli Coil to make sure everything worked out.
Thought I would post here in case any one else has the same misfortune. It was a difficult task to slowly grind that thing out of the hole using my dremel tool but it was sure better than any other alternatives I could think of.
This was on my 57 C-182 w 0-470L
Reason: Added affiliate link for BCP
C182 guy offline
Aircraft: 1957 Cessna 182 Skylane
Re: Broken easy out on exhaust flange!
Good to know! Few feelings are worse than an easy-out or drill bit that goes snap. Helicoil or timesert is a great lifesaver.
pilot offline
Aircraft: PA22/20-150
Former "Bushpacer" owner, joined the dark side and got a 182...
Way to stay calm. What's special about the rescue bit that keeps the threads intact?
Did you heat the cylinder head around the area of the stud with a propane torch prior to trying the ez out?
Looks a lot like some carbide bits I've used for the same application. Congrats on getting it fixed!
chedrick offline
Aircraft: Cessna 182M
If it was your 470 most should have rosan locking studs. Safety wise I prefer to take off the cylinder and send it out to an engine shop to be chucked up in a milling machine to remove and replace broken studs. It costs but for me its worth it for the Rosans.
TangoFox offline
Keep the Greasy side down!
This was on an 0470 and I knew I was facing removal of the cylinder if that crazy bit had not worked. But it did, and it worked well. I was able to position my dremel to get very near straight in vertical at the broken easy out.
The bit is some kind of super hard material. I had to cut one in half and it ate up two dremel cut off wheel before I gave up and broke it in half. It requires using very light pressure and keep the bit from grabbing so it needs a little movement to keep it with room to do it's thing. When I was done I think I could have drilled out the remaining stud and then re tapped back to original size as I was very careful to avoid enlarging the hole. In the end I felt better going up and size and installing a heli coil.
I had no idea there was an option like this out there so thought I would pass it on here in case someone does what I did...
C182 guy offline
6 postsPage 1 of 1
