A friend of mine who is very serious about maintenance had this happen recently. The aircraft is used for personal transportation and back country camping. The co-pilot main gear wheel broke apart during a normal landing on a paved airstrip. It was the inner half of the wheel.
Things got very busy when the tire expanded at the wheel separation. The 800x6 tire (it had 25# air pressure) expanded far enough to grab the brake caliper which cut through the tire and tube and almost resulted in a ground loop. The caliper bolts were bent which moved the brake lining plate and shim into the brake disc assy. The disc, brake lining plate and shim were were damaged beyond repair.
Here are some pics of the wheel half. The missing piece was not found. Note the discoloration of the metal on the pics. It seems the wheel cracked from the inside some time in the past and then finally let go. It may have been possible to see this problem with the tire removed from the wheel but the owner had replaced the tires within the past 6 months and did not see any evidence of this problem when the tires were changed.
