Bungee Question
Mon Dec 20, 2021 11:47 am
I put a new set of bungees on (Federal 1,500's) the skis recently and I have a hook question. The old hook had a little tab bent into it and a locking ring. The new hook does not. Should I be concerned? The bungees are under tension when I am in the air and my back cable is tight. I also went on one of the ski manufacturers website and watched a installation video just to see the bungee part. Their bungees have just a hook, no lock. Any thoughts would be appreciated. Maybe I am all good, but I would rather find out in writing than the hard way if it is otherwise. I thought about using the old hooks, but they may be older than me.
Thanks,
Pete
Old
New
pburns offline
509
- Aircraft: Citabria 7ECA
pburns wrote:I put a new set of bungees on (Federal 1,500's) the skis recently and I have a hook question. The old hook had a little tab bent into it and a locking ring. The new hook does not. Should I be concerned? The bungees are under tension when I am in the air and my back cable is tight. I also went on one of the ski manufacturers website and watched a installation video just to see the bungee part. Their bungees have just a hook, no lock. Any thoughts would be appreciated. Maybe I am all good, but I would rather find out in writing than the hard way if it is otherwise. I thought about using the old hooks, but they may be older than me.
Thanks,
Pete
Old
New
Interesting….I’ve never seen an end fitting like that old one. Looks like an added loop to give you something to get hold of. Not a bad idea, but the pic of the new one looks fine.
10588
mtv wrote:pburns wrote:I put a new set of bungees on (Federal 1,500's) the skis recently and I have a hook question. The old hook had a little tab bent into it and a locking ring. The new hook does not. Should I be concerned? The bungees are under tension when I am in the air and my back cable is tight. I also went on one of the ski manufacturers website and watched a installation video just to see the bungee part. Their bungees have just a hook, no lock. Any thoughts would be appreciated. Maybe I am all good, but I would rather find out in writing than the hard way if it is otherwise. I thought about using the old hooks, but they may be older than me.
Thanks,
Pete
Old
New
The loop slips down over the tab and it locks the loop so it can't slip off the fitting. Otherwise it just slides up and down the bungee, not really any good for extra leverage.
I have seen them before but the new ones work just fine. They are all that way now and have been for many years. I wouldn't worry about it.
5219
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
Excellent, thanks guys!
Pete
pburns offline
509
Tue Dec 21, 2021 10:57 am
Mine are a simple hook. Just another leap of faith one takes when ski flying
4197
Tue Dec 21, 2021 12:47 pm
I put zip-ties on the hooks. I doubt it does much good but it makes me feel better.
NunavutPA-12 offline
123
Sometime I put a few wraps of pipe wrap tape over them, can't hurt, also makes me feel better. Just a day or 3 away from the first ski flight of the season, I'm getting cranked up, though I hate taking the 29" Airstreams off.
4197
Those bungees just keep the toes of the skis up. The. Limit cables are designed to prevent a ski from “going over”. I’ve seen at least one plane land (nose high) with a broken bungee.
And, if you’ve installed them, you’ll know that they’re pretty tight.
10588
