Bush Pilot - Bad Film, Nice Beaver...
Bad is right
6983
I only watched the opening couple minutes, but that's not a Beaver-- looks like a Howard to me. Although the Beaver was introduced the same year as this movie (1947), a Noordyne Norseman would be a more typical bushplane of that era.
10600
That's a Norseman. Classic old airplane......can't say the same for the movie.
If you ever have the opportunity to see a Norseman under restoration, do it. The wings are a virtual lumberyard.
10579
I scrolled ahead a little this time and that is definitely a Norseman at about 4:30 into the movie, but the airplane in the opening scene is not a Norseman. The tail's different, plus look at the MLG protrusions where the forward float rigging attaches to the fuselage on the Norseman-- they're missing on the opening scene airplane which I'm pretty sure is a Howard DGA15.
I had an uncle who worked as an A&P in Alaska in the early 1950's, and to hear him tell it- not only were the Norseman wings a virtual ulumberyard, they could literally haul a lumberyard. Way more airplane that the Beaver-- and probably why DeHavilland came up with the Otter.
Timeline
1935: Noorduyn Norseman:
1947: DHC Beaver
1952: DHC Otter
10600
Howard. An early one. DGA-8 maybe? Doesn't have the guppyish belly of the later models. But wing tips and strut-to-wing fairings give it away, also the flat back of the fuselage.
Clay offline
102
ceh
Mon Nov 04, 2013 10:54 pm
Yes, it's a Howard in the opening aerial shots, with the Norseman appearing around 4:00+/-.
Hollywood has always seemed to have a weak eye for accuracy when it comes to airplanes in films, especially older ones. At least they were both on floats....
nonrev offline
47
If you watch the video longer you will see that they are suppose to be two different planes and pilots.
cstolaircraft offline
523
Yeah, but the movie is so painful to watch past the first couple of minutes! It fits up there with the WWII Army movies on how to avoid gonorrhea.
3801
Users browsing this forum: No registered users and 24 guests
