That is really interesting.... In a way your design requires VG's to be safe, but with VG's it does what you need, nose down attitude
So to clarify a bit, I am using power to fly the attitude I like to land at. Before with Bushwacker I would touch down with my tail a foot or so off the ground (modified wheel landing) I than used the brake pressure as needed to keep the tail up with the wings if you looked out almost level flight attitude. If I do that same landing now my tailwheel is on the ground, I therefore can fly with better visibility but the wing is closer to stalled if that makes sense, allowing me to fly slower... I never liked the airplane before without VG's and although I flew it for a few months the first time around without I could tell a big difference as soon as I installed them. I knew I was facing the same issues, they just were more apparent with the higher incidence on landing. I fly my Super Cub with no VG's because I don't feel it needs them, would they make the airplane safer in slow and close to the ground operations, the answer is yes but the airplane has great flight characteristics without them and I have never felt like I was on the ragged edge.
Do you have VG's on the underside of the tail as well? Also, which direction did you have to adjust the tail? I would guess in the stock location it would have felt very tail heavy and that you needed to raise the leading edge.
I also have the VG's on the tail and a gap seal on the elevator. I had it up above stock position by 1" for the first flight and I ran out of up elevator on landing along with not enough nose up trim. I lowered it to stock and that helped some, I then lowered it 1" below stock and that help more. I still have to hold back stick pressure when empty fully trimmed nose up, if I throw 35 lbs. in my extended baggage that goes away. I am currently building a horizontal tail surface that is based on the N.A.C.A. 0012 airfoil to energize my tail. It should require a lot less trimming and lower stick pressures when slow. It will probably be several months before I complete them but I think this should be the cats meow.
The way I have always visualized it is the center of gravity is in front of the center of lift which causes a nose down attitude, then the tail has 3-4* of negative incidence to balance equation. Kinda like the center of lift being the teeter totter with the fat kid on the nose (engine) and the light kid (H-stab) on the tail.
A few more questions about the fuel system if you don't mind, since I'm in the middle of mine.... what did you use for a transfer pump? Is it the stock maule part? Is that a facet shaker pump? What did you use for a boost pump?
Yes they are the Facet to transfer tips to mains. I have a CJ Aviation boost pump.
Also, any plans for balancing the injectors and LOP operations if you are on a long XC and are just trying to get somewhere with minimal fuel burn? I'm planning on running the Airflow performance fuel system like Batson so that I can throttle back and LOP to have super economy cruise just so that I have a way to conserve fuel or extend range should my mission call for that.
Have not given much thought to that. I currently see the EGT's within about 30 degrees of each other which is way better then what I see with a carb.
Oh, which prop are you running? Do you prefer aluminum or composite props. Curious to what you your opinion is on that given your backcountry experience.
I am running a Hartzell compact hub, metal blades, 84" diameter. Blade stops are at 8 degrees and 38 degrees according to the prop shop. I have played with the set screw on the hub and seen take off RPM's at 2690 the way it was first set up. I screwed the set screw in 1 turn and that dropped it to 2580 on take off (I did not like it as well so I am back to 2690). I am going to set the governor to allow for higher RPM's (2800-2900) and see what difference this might make. Right now at 2690 it does not feel like it pulls as hard as my 90" fixed pitch did pitched at 33 (turning only 2450 static). I hope to get it where I am using the full 200 hp and it pulls really hard.
Anyway, your build sounds super interesting, hopefully I'll get to see it some day.
