Bushwheel care, life expectancy, and resurrection
Another tip is not to lock the brake and swing the tail around on pavement. Make large turns and keep the tires rolling. This will help extend the life of the tire.
I know a guy that rhino lined his BW.
Jason
jgerard offline
46
Thu May 22, 2008 10:49 am
jgerard wrote: I know a guy that rhino lined his BW.
Jason
That worked? I've Rhino lined the tail wheel spring on an Ag plane that put out a lot of dry fertilizer, it worked for a while, but the fertilizer even ate through the Rhino. I wouldn't have thought it would be flexible enough to stay on a tire
a64pilot offline
1398
I bid up to 900. I will buy new after that. I have 2 sets of 31 radials i got used. I figure a few more sets and i will have a lifetime supply.
supercub185 offline
129
Bush flying,floats,wheels,skis
Ok had to try it, got a quart of Herculiner paint on bedliner at NAPA, put two light coats on a old pair of airstreaks I had, they were really getting sad..
So cleaned them well and wiped them down with thinner.... two light coats then drying for couple days.... mounted on cub and went out and landed on everything from gravel, rocks, shale, sand and even blacktop...spent several hours beating them in the ground....
with the rough finish I thought they might grab on pavement like crazy but no diff. from before...and they are flexible, look like new...the stuff seems to have just attached it's self to the old rubber....Consider the experiment a 9.5 !
Beats Shoe Goo hands down.........
glaciercub offline
322
The Good Lord does not deduct those days from our alloted quota, spent fishing, flying or with our Grandchildren.......
1749
Sun Jul 20, 2008 11:39 pm
Well John are you gonna give it a try?
mr scout offline
774
...if I hadn't sold mine, I would. Maybe at the next round of tires. John
1749
glaciercub wrote:Ok had to try it, got a quart of Herculiner paint on bedliner at NAPA, put two light coats on a old pair of airstreaks I had, they were really getting sad..
Ha.... Knew it.... got lifetime tires now...... cool.....
Coyote Ugly offline
897
Track My Spot
