Yes, I have about 7 or 800 hours in one. I've flown them on EDO 2000, on PK 2300, and on PK B-2300 floats.
Yes, the 2000's are somewhat underfloated, but note that the Max GW on EDO 2000s is NOT 2200 pounds. Read the Type Certificate.
The PK B 2300's are great floats, but not a lot of them around, unfortunately. The PK 2300's are somewhat shorter floats and DO NOT perform well compared to other floats.
I have not flown a 170 on Wip floats, but they might be a good option, if the $$$$ make sense.
I found that the floats didn't slow my airplane by more than a few knots, but my airplane is fairly slow as 170s go in any case--wing eccentrics are at the limits. Plan 100 knots, unless you want to push a good bit more gas through the thing, and gain a few knots.
With the PKs, you can go to 2200 GW, and with my airplane on the B-2300s, I could legally carry three "FAA Persons" (180 lbs each) and full standard gas (37 gallons) legally. On EDO's, you're going to be limited to a lower GW, and the plane won't perform off the water as well. Look out for turning in wind, etc.....I wouldn't go with the EDOs, though they are GREAT floats. Just not big enough for this airplane.
Send me a PM if you want more information, with specifics on what you have in mind.
