Cary wrote:
Couple of things:
While it takes more actual airspeed to get the wing to "feel" the same lift at high DAs, that does not mean more indicated airspeed. The indicated airspeed to use is the same as is used at lower DAs. A caution, though, and this not to pitch up as much as you'd do at a lower DA--it's way too easy to get behind the power curve so that the airplane won't climb. The better technique is to barely get off the ground, then accelerate in low ground effect (like less than 5' AGL) to something around Vy (not Vx, unless necessary to clear obstacles, remembering that Vx is a higher IAS at higher DAs), and then climb out at about Vy--and don't get impatient with the anemic climb rate. You can see this in my other poorly made video:
Yep. To clarify what I meant more, the ASI tells you what the wing "feels". So when it says 60 kts, then that means the wing feels like it is moving through the air at 60 kts. Your actual airspeed could be considerably more, though. (Basically what you said, I just explained it poorly earlier.)
Since you use the same indicated airspeeds for stall speed, Vy, Vx, etc. it helps keep things simple. Could you imagine if it didn't work that way? You would have to keep re-figuring your airspeeds throughout the flight!
I hear ya on keeping the nose down. I have noticed alot of pilots have a fear of flying close to the ground. They seem to think its going to reach up and grab them. Granted altitude is your friend, but so is airspeed.
I have done some safe, but very low altitude maneuvering with a CFI. Very enjoyable. Also, went up with the local crop duster in a Citabria and did some simulated crop dusting on our fields (we were bored and waiting for the turbulence to die down, so we could do aerobatics). Really helped get over the fear of flying low towards trees.
I watched your other video, and I definitely noticed the climb rate. That will take some getting used to.
