C-182 IO550
Okay I think I might need help, but thats an entirely different subject. I am just getting my overhauled IO550 on a new to me plane reinstalled. I am reviewing brake in procedure and after 25 hours the possibility of running LOP with my GAMI injectors. Part of doing this safely is being able to identify power settings as a percent i.e 65 or 75%. I don't have a manual for this engine that gives MP's and RPM for pressure altitudes to produce desire % of power.
Does anyone have an easy method for calculating this information.
mainewoodsstol offline
26
- Aircraft: Cessna 182 J
Don't know if you are updating your engine analyzer, or considering it, but EI's CGR-30P shows you your instantaneous % Hp. I presume their -50 model does also. It's a great instrument. I appreciated it during the break-in of my current engine, when it was factory-new.
-DP
2789
- Aircraft: C-170B+
In a normally aspirated engine, I use the following formulae to help me estimate % power.
RICH of PEAK
((Cruise RPM/Max RPM) * (Cruise MP/29)) x 100 = % Power
Example: At cruise at 23 squared.
((2300/2700) * (23/29)) x 100 = 68%
LEAN of PEAK
((14.9 x fuel flow)/Max HP) x 100 = % Power
Example: When 25-50 deg LOP. FF = 12 GPH.
((14.9 x 12)/300) x 100 = 60%
Good luck.
Squash offline
605
I think that is the first time I have ever seen that formula. Good info.
Flying Dave offline
210
- Aircraft: Aviat Husky
Flying Dave wrote:I think that is the first time I have ever seen that formula. Good info.
X2
5186
Squash wrote:In a normally aspirated engine, I use the following formulae to help me estimate % power.
RICH of PEAK
LEAN of PEAK
Good luck.
Thanks for these formulas! After some thinking the other day I came up with the same formula that uses manifold pressure and RPM, I unfortunately had I significant back ground in chemistry (which is really just math) in college and this seemed to make sense. I guess I just felt as if pressure altitude should play a role.
Also does the constant 14.9 represent a "standard atmosphere"? If so why not 14.7psi?
26
Fri May 04, 2018 12:32 pm
No, the 14.9 does not represent atmospheric pressure; hence not 14.7. It is a LOP conversion factor that is used for NA engines with a compression of 8.5:1 to convert fuel flow to HP.
Squash offline
605
