Anyone know if an STC exists to run 8.5x6 tires on a C150? Im installing on a TW conversion.
Thx-
Greg-
hotrod180 wrote:It doesn't help you now, but IMHO David Lowe dropped the ball if he didn't include approval for 850x6 tires as part of his 150 taildragger stc.
TR wrote:If no STC currently exists, there should be no problems obtaining a field approval on something as benign as 8.50’s.
I had no problem obtaining field approvals for 26” GY’s on our 180 and 29” tires on our Beaver. It was a straightforward process with documented flight tests required at forward and aft limits of the CG envelope.
Full disclosure, this was accomplished through the Fairbanks FSDO. Should be no different any place else in the country as the FAA is “standardized” throughout the nation![]()
TR
Bigrenna wrote:Anyone know if an STC exists to run 8.5x6 tires on a C150? Im installing on a TW conversion.
Thx-
Greg-
Zzz wrote:Apparently there is no STC, reading between the lines of responses.
Bigrenna wrote:Zzz wrote:Apparently there is no STC, reading between the lines of responses.
Yep, I figured there was nothing. Not interested in faffing about with field approvals… ordered a set of 26 inch Airstreak bush wheels. At only 20 pounds, they’re actually lighter than the Dessers… They’ll do nicely.
Zzz wrote:Bigrenna wrote:Zzz wrote:Apparently there is no STC, reading between the lines of responses.
I did find one potential lead in the FAA STC database: https://drs.faa.gov/browse/excelExterna ... 276EE.0001
I filtered by TC 3A19 with keyword "tire" and got 3 results. This Landes nose fork STC specifies mains up to 8.50. The only problem is you have to run a big nosewheel fork hahahaha. Tough to do on a tailwheel conversion but perhaps you can find a loophole.
Users browsing this forum: hotrod180 and 8 guests
