Thanks for the advice given above; it was spot-on! I found 24" x 36" x 3" closed foam pads at Wally world, and split them longitudinally with an oscillating knife. As mentioned above, I raised the tail so that it was a slight uphill climb and put a 20" fan in the cabin area blowing into the tail as it did tend to get warm in there.
I ended up replacing all the cables and pulleys and mounting hardware for same with the exception of the trim cable/chain and rudder cable's, which will be undertaken when I go through the stabilizor trim mechanism. Overall, it took about 80-90 hours, including replacing the flap tunnel carpet with a Selkirk cover in order to gain access.
Removing ratty carpet:
Primed tunnel, painted flap handle after removal, cleaning, inspection, greasing and painting, masked to protect paint when putting cover (aileron leveling board also shown):
Final cover:
I found two cables with a single strand frayed and a few with wear. Several pulleys showed wear. The flap clevis bolts were rusty and grooved and probably the worst of the bunch. Not too bad for about 60 years.
I wasn't able to gather much intel online regarding the process of changing cables, so I thought I'd try to write up my experience. Initially, it was my intent to replace a single system at a time, for example, do ailerons, then flaps, then work the tail group. However, changing the aileron involves the rudder and flap cables, as they share common stacked pulley's, so before you know it you have piles of pulley's and wads of cables. I found writing pulley location on the pulley's and stacking them with their associated hardware in the order of removal helpful, and checking the parts manual prior to removing them in order to know if there are any bushings around useful, too. Placing a magnetic retrieval tool adjacent to the work area helped capture the bushings, as they tend to wander off when you pull the bolts. Removing pulley's means you generally don't have replace the keeper cotter pins.
I used safety wire as a means of retrieving the new cables, but that got me into trouble at the aft wing roots when the narrow wire pulled the new cables into the wrong channel, as described above. An 1/8" or so cord might work better. Here are the correct configurations, looking inboard at the outer root:
Left:
Right:
The trim system will need to be disassembled in order to replace the forward chain and cable. In order to avoid having to re-rig the trim, I set the trim wheel so both chain ends were equal of equal length and marked the trim wheel with a gray Sharpey where the trim pointer indicated straight-up and also which groove the trim wheel groove follower was in at that position. Because I never messed with the stabilator chain guards, that kept the trim rigging intact. Also, the needle bearings on the trim wheel can be cleaned and repacked and the pointer freshened up with new white paint.
The flap handle should come out early and go in late, as it's going to be in the way of elevator/aileron cables and the only way I could remove/replace it's associated clevis bolts was with the handle out of the tunnel. The handle is kind of tricky to get out/in and there is a write-up here:
http://www.cessna170.org/forums/viewtop ... =24&t=7304That's enough for now; more to follow.
