DENNY wrote:The best way to figure out fuel level in a tank is fly it until the engine stops than go to the other tank...
Until the day you switch tanks, and find it empty due to an unseen fuel leak, or that you have an obstructed vent line that prevents fuel flow, etc.
Wouldn't it be nice to ALSO have an accurate-reading fuel gauge to tell you that your "other" tank has the quantity remaining that you believe it has? Or to be able to notice that you're losing fuel from that tank due to an otherwise unnoticed leak? That way you could immediately switch to the "leaky" tank and use all the fuel you possibly can before it goes overboard, then switch back to your known good, working tank. And wouldn't it be nice to know how much fuel is actually left in that "good" tank, so you can plan to divert if necessary?
DENNY wrote:...a good fuel flow meter will get you closer to empty than any gauge!!!
DENNY
While that may be true with mechanical float gauges that were certified years ago, I would suggest checking in with your experimental amateur built buddies who are flying with Dynon, Garmin G3X, GRT, and other systems that provide highly accurate fuel level indications... Several of them use magnetic-type floats (similar to what CIES is certifying and bringing to market), while others use capacitance-based probes that are likewise very accurate.
I flew several LSA aircraft (Sport Cruisers, Remos, and CTLS – all of them Dynon equipped) whose digital tank level readings were 100% confirmed when refueling to the filler neck (full, per the book). Likewise, my friend who put magnetic senders (sourced from EI, along with his CGR-30P) into his Rockwell Commander 114 says his "fuel remaining" on the gauges tracks within 1/10 gallon with the fuel remaining shown by the fuel flow instrument, and both show "fuel remaining" that matches within a tenth or two when he refills the tanks.
[#RANT MODE = ON]
We, as pilots, have been complicit in allowing the industry to get away with supplying fuel gauges that are a joke. We make up all kinds of reasons why "real pilots" don't need fuel gauges, even as we watch our friends and acquaintances kill themselves running out of fuel. In this day and age, when technology can solve this problem so easily, it is ridiculous the lengths that we go through to justify NOT making the change! How many more of our friends have to die before we become convinced that we need accurate fuel gauges? [#RANT MODE = OFF]
I, for one, applaud the efforts of CIES (and others) to bring accurate fuel level indications to the cockpit. The Bearhawk Patrol I'm building will have dual fuel level sensors: a highly accurate fuel level sensor connected to a gauge on the panel, backed up by a direct-reading sight tube visible from within the cockpit (though slightly behind the pilot's head). Oh, and it will also have a fuel-flow meter to track actual usage versus indicated fuel levels. The "difference" (if any) would likely indicate a fuel leak...
