Id like to swap my big bench out for 2 small jump seats. Anyone making jump seats that drop right in without any or much mods?
Ideally Id like to keep using the bench and then having the option of 1 or 2 jump seats installed instead.
firebird wrote:Great Im going to get a hold of my AME he has an upholstery guy, I might get lucky.
bat443 wrote: The factory jump seats will not work in the 1976 A185F or 180J as they do not have the "Bracket Assembly-Rear Seat Attachment" part number 0511312-1 where the rear attachment screw secures the seat to the side wall. ....
and the FAA is very picky about seat belt attachments, requiring field approvals of the attachment to the floor when the back seat is removed. ....
bat443 wrote:... The seat belt attach bracket you show in the photo is the same or very similar to the factory seat belt attach bracket in all 185's and 180's starting with serial number 18051313 (1964 180G). 180's prior to this did not have those seat belt attach brackets installed at the factory. If I was going to install jump seats in an early model 180, those are the attach brackets I would use. Tim
bat443 wrote:The factory jump seats will not work in the 1976 A185F or 180J as they do not have the "Bracket Assembly-Rear Seat Attachment" part number 0511312-1 where the rear attachment screw secures the seat to the side wall. The serial numbers of the airplanes that these seats were originally installed in are 185-1150 thru 18502838 and 18503152 and on, and 18051775 thru 18052620 and 18052771 thru 18053203. ....
hotrod180 wrote:FWIW after having one of these factory jumpseats,
I do find my BAS folders much more satisfactory.
More leg room for the sitter,
and easier to always have for that unexpected passenger.
hotrod180 wrote:I didn't bother with the toggle style bolts for the side attach,
just used regualt AN bolts & a wrench to install or remove.
I'd like to read the service bulletin to see what it says.
Users browsing this forum: Bing [Bot] and 0 guests
