4Whitey wrote:Does this "sounding" test apply the same to constant speed and FP props?
Unfortunately, Ive got a consistent THUD on just one blade of my 11 year since overhaul, 800 hour McCauley 402, where the other two make the nice "dinnggg" sound. Blade looks fine.
I talked to an experienced IA mechanic who'd never heard of this procedure and was somewhat skeptical and suggested cycling the prop and retrying the sounding. Did just that and the sounding is exactly the same. The same blade makes a short "thud", while the others make the nice (almost music quality) ding when knocked. Any suggestions?
kevbert wrote:A buddy of mine had been a helicopter mechanic in the army, and waiting for him to finish his airplane preflight inspection was like sitting at the dentist's office. It truly seemed to take forever.
One of his many procedures was to always rap each prop blade near the tip with his knuckles like he was knocking on a door and listen to the sound. One time we were renting a plane in Seattle, and after his usual obsessive-compulsive knocking on the prop, he looked over at me and said we were going to have to get another plane, because the prop was cracked. I was highly skeptical, so he had me rap each end, and sure enough, you could hear the difference. One blade had a ringing sound to it, and the other had a clunking sound with no ring. The local mechanic took off the spinner, scrubbed the prop near the hub with some dye and a brush, and eventually spotted a fatigue crack that was just getting started.
That was about fifteen years ago, and I have rapped my prop on every single preflight since then!
M6RV6 wrote:Get the damn thing checked!!
Did you not read these posts!!
Rant OVER
GT
I had the prop dye penned and visually inspected by another AP-IA although he didnt remove the blade from the hub, nor the paint. Nothing found.
the first AP suggested that a constant speed prop is assembled with shims that could affect the sound you get when you thunk on the end, so this may not be a reliable test.
wyomingiswindy wrote: ......... I had an instructor tell me he fixes the engine to the fuselage somehow with a cable. Has anyone ever done that? It seems like a dangling engine with a wild prop wouldn't be much better than a lawn dart, but............
I would have to ask why it seems to work on two out of three blades. Have you tried it on another similar prop? I have been aware of the ring test as applied to cranks and castings most of my life, suspending the part by a rope and smacking it, it should ring if it does not its cracked, works every time without fail, as for a prop blade in a hub, I just don’t know, I find it unlikely that there could be a crack in the blade and not in the paint, preventing a dye penetrant test from showing it, (I’m open to correction on that statement) but then what if the crack is in on the hub end where you can’t see it?4Whitey wrote:M6RV6 wrote:Get the damn thing checked!!
Rant OVER
GT
GT your rant is much appreciated. I am a conservative owner and have maintained this 206 with an open check book. I talked to an experienced AP-IA and another IA who is a prop shop owner. Neither had heard of this and the first AP suggested that a constant speed prop is assembled with shims that could affect the sound you get when you thunk on the end, so this may not be a reliable test.
Prop shop owner says he'd fly it until I can conveniently schedule down time, then OH the prop, due to age not due to dull sounding of one blade. Says if there's no obvious crack or fluid leaking from hub it's likely OK for now.
None of these three mechanics have ever heard of this "sounding" test, I'm not saying its not legit, I'm saying based on the professionals I've spoken to, none of them know if this is a legit test for a prop. If I took everything I read on the web or in forums as gospel I'd be a paranoid wreck. I plan to OH the prop soon, but not tomorrow.
Does anyone know if the sounding test is reliable for finding cracks on CONSTANT SPEED PROPS? Thank you.
172heavy wrote: but then what if the crack is in on the hub end where you can’t see it?
hotrod150 wrote:wyomingiswindy wrote: ......... I had an instructor tell me he fixes the engine to the fuselage somehow with a cable. Has anyone ever done that? It seems like a dangling engine with a wild prop wouldn't be much better than a lawn dart, but............
I belive some Reno racers install a "safety cable" like that. A dangling engine might give you some crazy aerodynamics & no power, but at least your CG wouldn't suddenly be so far aft that you'd go into a fatal tailslide.
