Hi all,
For those of you that hung on my every word, I apologize for being quiet for so long. Happy to say I've been busy flying and learning.
Our '63 182 is supposed to be back on EDO 2790 amphibs as of this afternoon. I'm going to post about my journey learning to fly amphibs on the float flying forum but it raises an issue that probably fits better under campfire (or maybe maintenance?).
Since we bought the plane last year I've been pretty religious about flying with lots of fuel but that will change with heavy amphib floats hanging underneath. Cessna fuel gauges are notoriously crappy but I've found my engine monitor (EDM900) to be very accurate. When I refill I simply hit 62 gallon refill and the indicated fuel burn is remarkably close to what it takes to refill the tank. Problem is, I won't be able to accurately measure how much I'm adding when I fill part way so I'll have to dip the tanks.
I don't think anyone sells one pre-calibrated so I'll need to build something myself. I've been told that a stick with a float side and a pavement side is the way to go but I can't figure out how to calibrate it.
Is the only way to start with empty tanks and slowly add fuel and mark the stick accordingly?
