Backcountry Pilot • Canyon Flying
Canyon Flying
23 postsPage 2 of 21, 2
Re: Canyon Flying
bumper wrote:I used some black polyurethane tape (McMaster-Carr on-line) on the forward portion of the V-brace tubes on my Husky. Works nicely and seems to be impervious to the typical tape issues in the heat and UV, As an aside, I use the same tape on the leading edge of my horizontal stab to help prevent stone nicks.
On that earlier video I posted of the E. Fork of the Carson River. Yes, the water is low and there are several landable spots. When the water is high in the spring thaw, there are only two I'll land on, one is where I made the right turn and did a low pass over a dirt road. There's 400' landable there, which is comfortable and doesn't require heavy braking (about 5,000' MSL). The second is really two gravel bars, or usually is. First is short and I ski between the two and roll out on the second. Narrow, and trees on one side, so not excessive wing clearance.
bumper
Thanks Bumper for the tape recommendation! It's on the way so should get to try it out this weekend. I was reluctant to use other tapes due the durability issues that you suggest this tape addresses. If we get a chance it would be fun to fly the E Carson sometime.
Thanks Cary, for me at least, I'm just starting to get antiquated with the camera, mounting options, etc. Those GoPro images look great so eventually, I'll have to try one.
Mike
blackrock offline
Aircraft: Bearhawk
Re: Canyon Flying
Bumper,
The tape you recommend arrived today. That is perfect for v-brace anti glare as you said and some really serious tape. I nearly drove myself insane applying the first strip as it sticks so well especially to my fingers and its self! Once I went through the training class, it went a lot smoother. My only regret is not ordering 2 rolls instead of just one.
Thanks,
Mike
blackrock offline
Aircraft: Bearhawk
Re: Canyon Flying
For reference, this is what I ordered and assume it is what Bumper recommended.
http://www.mcmaster.com/#7571a1/=ol2iad
blackrock offline
Aircraft: Bearhawk
