My 182 has several 1/4 28 tapped bosses (heavy nut plates) in the flore for tie downs. Where can I get the tie down rings.
qmdv wrote:.... I need some devices that will go into the existing 1/4 28 tapping in the floor.
qmdv wrote:My 182 has several 1/4 28 tapped bosses (heavy nut plates) in the flore for tie downs. Where can I get the tie down rings.
hotrod150 wrote:qmdv wrote:.... I need some devices that will go into the existing 1/4 28 tapping in the floor.
"Devices"? Come on Tim-- this ain't rocket science.
There's a good reason why the Navy stuck him on a submarine...
GumpAir wrote:hotrod150 wrote:qmdv wrote:.... I need some devices that will go into the existing 1/4 28 tapping in the floor.
qmdv wrote:No crepes for you guys in Austin![]()
182 STOL driver wrote:qmdv wrote:My 182 has several 1/4 28 tapped bosses (heavy nut plates) in the flore for tie downs. Where can I get the tie down rings.
Tim and Flight ----
Check out http://www.cargosystems.com/46dapmf.htm#anchor for tiedown points. and http://www.cargosystems.com/store/produ ... t=0&page=1 I've got a place in Kingman that makes the nets --- Net runs about $50 bucks and ties into anchor points.
