I checked Part 43, Appendix A, Paragraph C, and it says that this is OK for me to do since this is a tray-mounted ADF and simply slides out.
(c) Preventive maintenance. Preventive maintenance is limited to the following work, provided it does not involve complex assembly operations:
31) Removing and replacing self-contained, front instrument panel-mounted navigation and communication devices that employ tray-mounted connectors that connect the unit when the unit is installed into the instrument panel, (excluding automatic flight control systems, transponders, and microwave frequency distance measuring equipment (DME)). The approved unit must be designed to be readily and repeatedly removed and replaced, and pertinent instructions must be provided. Prior to the unit's intended use, and operational check must be performed in accordance with the applicable sections of part 91 of this chapter.
So I have three questions -
1) The wording seems imprecise in the FAR. Am I allowed to remove the ADF without replacing it? "Removing and replacing" can either mean I am allowed to remove the ADF, and I am also allowed to replace it. Or it can mean I can only remove it in order to replace it.
2) any issues with doing something like this? I was planning on just making a logbook entry that I removed the ADF, and keeping the ADF in the hangar if I ever want to slide it back in.
3) are covers made to fill the hole?
