Cessna 170B/Avcon engine mount to firewall bolts
Tue Mar 01, 2022 11:51 am
Anyone here know what bolts are specified for the engine mount to firewall for a 1952 Cessna 170B with the Avcon 180 HP engine conversion. I couldn't find any mention of it in the plans. Thanks Gary
shortfielder offline
2352
- FindMeSpot URL: http://share.findmespot.com/shared/face ... D263l9HKFb
Wed Mar 02, 2022 10:52 am
I think you want AN6-33A for the lowers, and AN6-22A for the uppers. The length is critical so it doesn't get bottomed out. The drawing shows two washers under the bolt head for the lowers.
I ordered these lengths for my Del Aire STC and they worked fine.
You need to decide if you want to keep the rubbers or go to seaplane solid aluminum bushings. The washer on the inside (0550153-1) under the nut is hardened I think, so don't swap them out.
1302
Thu Mar 03, 2022 10:06 am
FWIW Gary I would go with the seaplane bushings.
I swapped out the rubber bushings on my 180 a year or two ago,
and the solid bushings seemed to smooth things out a bit.
They will also last forever, unlike the rubbers.
10604
