I bought the 170 a year and a half ago, it has an O360 Lyc, it started easily, just followed what the book procedure said and started usually on the first try (cold or hot)
Book Procedure is
Battery ON, Alt ON Fuel pimp ON, 5 shots of primmer, 25% throttle in, left mag ON, press start button.
Plane started easily but in cruise at low power setting ran bad, hiccups, rough, after trying a few things that did not helped, we replaced the carburetor, now it runs very smooth, that problem was fixed, but now it is very difficult to start, specially when cold, I follow this same book procedure and it wont start, also tried 6 primmer shots, 5, 4 and 3 and does not want to start, carb idle is as should be , also I get the rpm rise before the engine stops, when shutting down.
Now it starts after many tries and waiting a few minutes, pumping the throttle, while starting, or leave more than 25% in works after many attempts.
Any ideas on a fix for this? Definitely the book procedure does not work anymore.
