motoadve wrote:I did kept my Horton wingtips they have bigger area than the ones Stene offered at the time , and they recommended me to do that.
Have not seen the new tips in their website.
172heavy wrote:.... My norm was 100mph and 950-1000 ftpm now after the Sportsman its closer to 850-950, am I the only one?
akgreg wrote:Flap gap seals - off. Improved performance - yes. Thanks for the input.
robw56 wrote:Stene Aviation just came out with a new wingtip design also which adds even more wing area than before (which I have on my plane). According to them, the cuff and wing tips add nearly 9sq.ft. to the 170 wing.
Jeredp wrote:akgreg wrote:Flap gap seals - off. Improved performance - yes. Thanks for the input.
Can someone elaborate on this? Ive never flown my plane without the b&m flap and aileron seals so I'm curious about the performance gains. Thank you
mtv wrote:Jeredp wrote:akgreg wrote:Flap gap seals - off. Improved performance - yes. Thanks for the input.
Flap gap seals are designed to increase cruise speed. They do that, at least on Cessnas with para lift flaps, by preventing the flow of air from the underside of the wing flowing to the upper side of the wing through the gaps between the wing and flap. . That occurs PRIMARILY at flaps zero in cruise, but those flap gap seals also reduce the flow of air from bottom to top with flaps deployed, thus reducing the effectiveness of those big flaps. Semi Fowler flaps rely at least partially on the flow from bottom to top of the flaps to keep the airflow attached to the top of the wing at high AOA.
In short, partially blocking those Fowler gaps defeats the effectiveness of the flaps. Not bad on a 210, but a uniquely bad idea on any backcountry plane.
Fisherman wrote:I wonder if it would be possible to design a flap gap seal that would automatically retract when the flaps were deployed so that the Fowler flaps could do their job. Maybe that someone could call it EZAUTOGAP!
