cessna 172 rear seat weight
Hey guys i was trying to get a good guestimate of the rear seat weight of our 172K. I want to have an idea before i weigh it tomorrow
Thanks
Tom
Tom offline
791
- Aircraft: PA-18 7EC C-172
Can't locate my notes, but I'm pretty sure my rear seat is 23 lbs. I fly a '53 170 B, but the seats are from a later model 172. Real classy too- brown vinyl, fuzzy upholstery, and gold piping for the trim.
2789
- Aircraft: C-170B+
Rear seat in my 53 170B was covered around 1995 or so, and weights approx 32 lbs. They had to have improved the weigh of the seat frame by the time the 172K rolled out though.
2855
I do weight and balance and do some with and some without back seat(s). Back seat -bench type will generally run 25-28 lbs. Only way to get it right is weigh it ---get shop or A&P to make out new Weight and Balance. Depending on aircraft and where it's happening W&B runs from $200-- to $500 bucks. I do single/Helicopters and experimental's as well as twins .Fuel Empty or Full your choice . Have scales and computer can travel .Usually take 2-3 hours and Hanger . If you have several aircraft same location/time I will give everyone a little brake +travel expenses .
182 STOL driver offline
1529
Fri Aug 06, 2010 11:09 am
As I recall my 170 rear seat weighed about 32 pounds.
10534
61' 172B. 23.65lbs includes seat belts.
GroundLooper offline
1168
BCP Poser.
My '67 T41B (same interior as a '67 172) weighs 21.6 pounds with Airtex covering. Rear seat belts are 2 pounds total.
mr.helix offline
61
making 'em spin. . .
