Anyone know if the straight tail 175 is the same airframe as a straight tail 172 or 182?
If different than a 182, how so?
And are all 175's manual flaps?
58Skylane wrote:....I'm not a fan of the Franklin geared engine, but many of the 175's been converted with different engines. .....
hotrod180 wrote:58Skylane wrote:....I'm not a fan of the Franklin geared engine, but many of the 175's been converted with different engines. .....
Not sure what you mean about Franklin geared engines.
The C175 came from the factory with a Continental GO-300,
a higher-turning version of the O-300 with a reduction drive gearbox on the nose to reduce prop rpm.
Not sure what the prop rpm or gearbox ratio is.
The GO-300 is not a highly touted engine, it's true,
but it might be because most people don't know how to operate geared engines properly.
*drift* Lycoming's series of geared engines, the GO-435 & GO-480, have seen some use.
They were factory-installed in Helios, Twin Bonanzas, Piaggios/Fockwolfe 149,
and some others. Also seen them used as conversions in Widgeons & Seabees.
Lotsa power, fairly low weight, unfortunately pretty expensive to overhaul.
robw56 wrote:What Hotrod180 meant is that the 175 doesn't have a geared Franklin engine. I don't think I've ever heard of a geared Franklin. The 175 has a geared Continental GO-300.
An unusual feature of the 175 is the geared Continental GO-300 engine. Whereas most single-engine airplanes use direct drive, this engine drives the propeller through a reducing gearbox, so the engine runs at 3200 rpm to turn the propeller at 2400 rpm. The GO-300 engine suffered reliability problems and helped give the 175 a poor reputation. Some Skylarks flying today have been converted to larger-displacement direct-drive engines[3][4] though almost 90% still retain the GO-300.[5]
The GO-300's tainted reputation was largely undeserved, since its problems were the result of pilots who were unfamiliar with gear reduction engines simply not operating the engine as specified in the C-175 Pilot's Operating Handbook. Pilots unfamiliar with the engine often operated the engine at the low RPM settings (2300-2700) appropriate to direct-drive engines, while the 175's Operating Handbook called for cruising at 2900 RPM. The low RPM caused harmonic vibration in the reduction gear between the quill shaft (that turned the propeller) and crankshaft, and the low power resulted in low airspeeds that prevented the engine's air-cooling system from operating effectively . . . resulting in chronic reliability problems for engines not operated at the recommended power settings.[3]
