Here's a link to the text of the AD being discussed (90-21-08):
http://rgl.faa.gov/Regulatory_and_Guida ... t=90-21-08From that AD:
"To preclude undetected fuel loss on airplanes equipped with an over the wing (above cabin top) fuel vent tube, accomplish the following:"
and
"(b) When the left fuel bladder is removed for any purpose, modify or install a fuel tank (bladder) equivalent to Cessna Part Number 0726000-13 (fuel vent in the outboard end of the fuel tank container), and relocate the primary fuel vent opening to behind the left lift strut in accordance with Cessna Service Kit SK 180-6. (Under the wing primary fuel vents behind both the left and right wing lift struts are acceptable). "
However, according to Pitts Driver, service kit SK-180-6 is unavailable. How can the FAA expect people to install something which is no longer available?
Something else from the AD:
"(f) An alternate means of compliance with this AD may be used if approved by the Manager, Wichita Aircraft Certification Office, Federal Aviation Administration, 1801 Airport Road, Room 100, Wichita, Kansas 67209.
NOTE 2: The request should be forwarded through an FAA Maintenance Inspector, who may add comments and send it to the Manager, Wichita Aircraft Certification Office."
I wonder if any has ever had an alternate means of compliance approved, perhaps a fairing in front of the existing overwing vent as described by 180Marty?
