Backcountry Pilot • Cessna 180 Gear Leg Cover
15 postsPage 1 of 1
Anyone know where I can find this part for my '55 Cessna 180?
[img]
[/img]
Jacking 180.jpg (118.78 KiB) Viewed 1485 times
Deputydog offline
Re: Cessna 180 Gear Leg Cover
Try Stene Aviation in Polson, MT. They make a lot of those kinds of parts, and good quality stuff.
This ad ran for years in the 180/185 Club newsletters.
No idea if the guy is still around.,
or if he still has those two sets of gear legs seals.
(riiiiight)
"Gear Leg Seals for
180/185. Two sets.
Buz Landry
512-965-5452"
Ok thank you very much!
Deputydog offline
Frankly, it wouldnt be that hard to make one from sheet metal, for that matter.
Buzz is still around... but he only makes the rubber gasket part - which is frankly the most important. Will Stene makes nice covers but a lot of us just have basic parts cut out of sheet metal.
Deputydog,
Care to share what you attaching the jack chain to you the floor jack with on the gear leg?
Thank you. I've been trying to come up with a safer way to jack up my 185. I'm going with a hoist like you have but have not settled on the attachment mechanism.
Thank you
MW
185Midwest offline
Aircraft: C-185
185Midwest wrote:...Care to share what you attaching the jack chain to you the floor jack with on the gear leg?
Thank you. I've been trying to come up with a safer way to jack up my 185. I'm going with a hoist like you have but have not settled on the attachment mechanism. ...
That looks like the high-strength line (amsteel?) that Hammer posted about using several years ago.
I hoist mine in a similar fashion but I use a nylon strap, wrapped around as a "choker" like this photo shows.
https://amzn.to/3qHfRGx
I use one of these wrapped around the lower leg and an engine hoist. The amsteel is waaay strong but I can't get past looking at that skinny line holding that much weight
Reason: Added affiliate link
TangoFox offline
Keep the Greasy side down!
Thanks everyone!
Just ordered the straps from Amazon.
MW
185Midwest offline
Aircraft: C-185
Was about to say dyneema (can get at west marine), splice both ends and make a sinch
TangoFox wrote:https://amzn.to/3qHfRGx
Just visualize it as stainless steel cable, it meets or beats it
Also can always get a thicker line
I went with something a little thicker when I made my pup a leash, just for comfort in my hand
Cool science though, strong as steel but floats
I was able to get ahold of Buzz Laundry for the seals.. And I made a pair of the covers so I think I'm set.
Oh and that 180 isn't mine, it was just a picture I found so I could point out the part I was looking for since mine was missing.
Deputydog offline
Hiw much were the rubber seals?
hotrod180 wrote:How much were the rubber seals?
$75 shipped
Deputydog offline
15 postsPage 1 of 1
