Fri Dec 09, 2011 12:23 am
Wool is easier to install but gets dirty and is difficult to clean. And if you get any water leakage or condensation? Not pretty. My last one was wool. I didn't like it much. I have a brand new white vinyl headliner for a late model 180/185, still in the plastic wrapper from Aircraft Spruce's upholstery shop. I'll let it go cheap if anyone wants it.
Whatever you do, a major key in the success of your next installation is the care you take in the current headliner removal. A Cessna headliner is held in place with several wire hoops that are stressed between the sides of the airplane. Those hoops are "hung" under tension from little hooks that are riveted to the ribs in the cabin roof. The hoops are very important pieces, Treat them with respect and don't bend them. The hooks on the ribs are equally important and are old and fragile. You're going to break a couple. Minimize it. And if that's not enough, the fabric is tucked around the sides and front perimeters into little channels with tiny, fragile teeth that grab the headliner and maintain fabric tension. When you pull out the old headliner you'll break and bend some teeth. Again, minimize the damage. You're already going to spend enough time straightening out what teeth aren't broken off. And last, the tail of the new headliner will be glued to the bulkhead that defines the baggage area. Glued, tucked, and wrapped to look good. Not difficult but not something the average guy does every day. And once again, be patient when ripping out the old. You're going to have to clean up the mess so it doesn't show through your new headliner. Honestly? Most guys would be better off letting an upholstery guy with experience do the new installation. I'd expect the labor fee to be a couple of hundred bucks for about 2 hours work. Money well spent in my experience.
