Oregon180 wrote:Have you checked if the F&M (short) adapter would work? That's what I have. It's a bit of a PITA to reach the filter, but I liked the idea of no extra hoses for the oil to go through.
Scolopax wrote:I am looking for a spin on oil filter installation that works in a Cessna 180H (Standard O-470R installation) with a seaplane engine mount. All that I have seen interfere with the vertical tube that connects the upper and lower engine mount clusters. Does anybody know of a compatible installation?
moved it recently to the mount itself
Scolopax wrote:Bump.
Does anyone have experience with the Airwolf remote oil filter in the Cessna 180?
Who has opinions about oil filter installations? Are they worth the weight and money? My guess is yes, but I can't say for certain.
fredy wrote:.....The biggest thing with F&M is to be aware of their bulletin (can't remember if it's an AD or not), but if the mount itself ever has to be re-torqued, the two gaskets have to be replaced (1 copper crush washer, 1 cork like gasket). There have been engine failures due to loss of oil pressure and in all cases that I'm aware of it was found the owner reused the gaskets and the adapter came loose in flight.
Halestorm wrote: I’m running out of room on my firewall for more stuff. Not sure where I’m going to put a remote filter setup...
