To high and it wont steer. It also gives holes and rough ground more leverage to rip the nose gear off. The manuals all vary per year, some are "X" inches, some are "X" PSI. For back country ops put a piece of hose on the bottom of the strut to prevent metal to metal contact when it bottoms out.flyer wrote:I wonder if there is any problem with have 4 or more inches. That would increase the prop clearance. It also depends on how heavy the plane is. I wonder if there is a best height for the backcountry.
mtv wrote:First thing I’d do on that plane is install an Airglas nose fork and bigger (much bigger) nose tire. OR stick to pavement ONLY. That’s simply not enough clearance.
Second, once you get that bigger nose fork installed cut a piece of heavy duty hose, split it and attach it with hose clamps to the lower end of that strut. Prevents damage from bottoming due to impact or low pressure, and guarantees at least minimal prop clearance.
Not sure there’s a 206 in Alaska that doesn’t have a piece of hose on the strut. Saved lots of prop damage.
But, seriously, stick to pavement till you get more clearance.
DJ Balla wrote:mtv wrote:First thing I’d do on that plane is install an Airglas nose fork and bigger (much bigger) nose tire. OR stick to pavement ONLY. That’s simply not enough clearance.
Are you referring to the plane in the original post or the one I described? Also, how tall do most folks make the rubber tube stopper?
Thx
mtv wrote:DJ Balla wrote:mtv wrote:First thing I’d do on that plane is install an Airglas nose fork and bigger (much bigger) nose tire. OR stick to pavement ONLY. That’s simply not enough clearance.
Thx
Referring to all the above.....three inches or so of prop clearance just isn't going to work well on backcountry strips, and frankly, I've been on a number of "not so" backcountry strips that would be problematic. Sometimes, you have to get OFF that nicely manicured grass strip, and maybe the adjacent "parking areas" aren't quite so well groomed. We had a prop strike at a backcountry strip last summer I watched, with the pilot of a 172 trying to get off the strip for a plane behind him. He managed to luck out in taller grass and got the nose wheel into a small depression and the prop hit dirt.
As to size of the rubber hose: Maybe 2 or 3 inches. It functions as both a soft stop to prevent damage in a deflated strut, and prevent nearly full compression of the strut.
Kickrjason wrote:Any examples of this available to point our mechanic in the direction of?
