At present we have no stall scoop or horn on our Cessna A185E. We are going to install sportsman STOL kit.
Do you have aby tip what stall warning mechanism / lift indicator to install and where to buy it?
Thanks.
Pavel
daedaluscan wrote:….I found with my Sportsman install that the radius of the leading edge where the vane now goes is tighter than the original and the mounting plate needs to be rebent to fit the new shape. As a result I think it would be fairly difficult to actually move it much. The jig that Sportsman supply makes it easy to get the vane where it should be.....
