This^^^[email protected] wrote:Did the bolts attaching the stab to the jack screws come in without the least need of lifting or pushing down on the stab?
They should slide in easy.
Surprising how uneven load on jack screws can create the problem you describe.
Less tension on the cables can sometimes also help.
flybaker family wrote:Question for my 180/185 flyers with STOL modifications. I recently purchased a 1966 A185E. It came with the MASA LE cuffs and the full Micro VG’s on the wings, and Vert/Horiz. stabilizers. Both appear correctly installed. Everything else aerodynamically is Cessna stock. At speeds around approximately 130 knots and above the trim starts to get progressively harder to trim nose down. This has been true from day-one of my ownership (2021). We have removed the stabilizer and fin for the AD, replaced all hardware, overhauled both trim actuators, adjusted tensions, cleaned, inspected, lubed everywhere, and inspected for correct parts/installations/adjustments, etc. We can duplicate this issue on the ground by loading the LE of the Horiz. Stabilizer. My AP/IA suspects that the VG’s on the lower surface of the TE of the Horiz. Stabilizer are putting ‘non-factory’ aerodynamic loads on the stabilizer, and causing the trim issue. Anyone else having this ‘phenomena?’
