Cessna abrasion boots install.
I bought the Cessna abrasion boots, but they are straight.
For pilots who have installed the Cessna abrasion boots on the 170 horizontal stab, what is the trick to make a smooth look on the round areas of the stab?
motoadve offline
1423
- Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Aryana offline
936
- Aircraft: 1955 Cessna 170
Fri May 21, 2021 12:58 pm
I don't use heat, just a helper for an extra set of hands. Excellent results. Prep with MEK and bond with 3M contact adhesive (1357?). Last application held up for over a decade. Personally I'd be cautious of too much heat degrading the 3M contact adhesive. Leave long on the outboard side of the stab and trim once adhesive is fully cured. Some blue tape on hand for good measure.
-DP
2789
- Aircraft: C-170B+
