Does anyone have any idea what they would be from? What other Cessnas used this style?
Thanks,
Chris
wannabe wrote:Not sure if this ""link"" will work. Found on Aircraft Spruce under CABIN ENTRY STEPS FOR CESSNA.
There is a chart at bottom which claims they go on a lot from 170 - 170A etc on up through 185 ---
Chart shows serial # ranges. May need to contact for specifics.
Look like one I had to repair on my 170-B
https://www.aircraftspruce.com/catalog/ ... rystep.php
Hope it helps - hope it does not violate any BCP rules.![]()
Wannabe helpful
mtv wrote: They look like the Cessna 170 or 140 steps. But I never pulled one out of its mount to see what the upper part looks like. MTV
[/quote]mtv wrote:
The C120/140 used boarding steps mounted on the gear legs, but I wonder if maybe someone modified a set of steps to install on a C120/140? Or more likely, on a C150 taildragger?.
obxbushpilot wrote:..... Mine are either positioned wrong or something because I cannot for the life of me figure out how to use one to enter the left side of the plane. If I stand on it with my left leg, I can't pull my right leg in and over the seat and if I use my right leg I have to cross my legs and can't pull my right leg around the seat.
it's hard to tell but it looks like the step *might be* a little farther forward than the factory 170/180/185 location.
Trimtab wrote:....Even found a supplier named Johnny Williams - no details .......
Trimtab wrote:... Mine - 170-B the step is close to the middle of the door.....
Looks like Bolen ?!? may have used the OLD gear leg hole to mount the step on yours.
Just a guess - but yes it is further forward than my original 170-B.
Even so - I always slid the seat all the way back before getting in.
With the seat all the way back - and your step a bit forward - just might make it a bit easier. Who knows.
obxbushpilot wrote:it's hard to tell but it looks like the step *might be* a little farther forward than the factory 170/180/185 location.
Yes. If the step were 6 inches farther aft, it would work great. I understand the learning to maneuver thing as I had pacer before this, but this step is just in the wrong place on this plane. I'd be better off removing them and selling them on ebay. I'd lighten up, reduce drag and have a few bucks for the annual maintenance fund.
Trimtab wrote:....Looks like Bolen ?!? may have used the OLD gear leg hole to mount the step on yours.
obxbushpilot wrote:....Because the step is so far forward, It's too close to the most forward part of the door opening and really isn't useful at all for a tall person. a shorter person might find it more useful....
