Turns out that there was only one snap holding the bladder on the top
A couple of the snaps actually came off the bladder and worked their way underneath. Its a wonder that there are not any holes with those snaps rubbing around under there. The leak was from the sump drain clamp that is internal working loose, in other words can only be adjusted by removing the tank. Since, the tank is not damaged I could put it back in, but being 19 years old and having the new one enroute, just gonna replace it and be done with it. Other bladder was new in 2006 so hopefully we're good for many years to come.
About 2 months ago my right hand stock cessna electric fuel indicator began to flicker wildly when the tank was not completely full or less than a 1/4. I checked the wiring and everything was good. Should have removed the filler neck port, it was obvious something was not right when I removed it to check the cork gasket. Now I know it was talking to me and trying to say that something was wrong with the bladder, could have saved a lot of trouble due to the bad timing of this failure. Moral of the story, listen to the airplane it usually tries to tell you when something is not right. I am pretty good at that but with this instance didn't know what to check and should have consulted more friends about what could be the cause. The cause being that the bladder was sloshing around in the wing, since the snaps were coming undone. My IA buddy is of the opinion that the bladder was not installed properly from day one, pretty important to get critical things like fuel bladders done right. So I'm paying the piper and having them do the install, well maybe its cause I'm going snowboarding instead
Thanks for the help y'all.
