Backcountry Pilot • Cessna pax vent replacements
7 postsPage 1 of 1
Anyone have experience with a more modern replacement for the rear Cessna vents? Preferably something of the same diameter and screw pattern as the original so it can mount to the existing can. I see some options around online but reviews are mixed and some require more extensive modifications. I'm installing new vents for the crew seats, these vents are the only thing that feels cheap/dated in the cabin so I'd like to replace them for aesthetics and function.
CParker offline
Aircraft: 1979 TU206G
Re: Cessna pax vent replacements
CParker, I replaced those old plastic vents in my 1977 C180 with Bonanza eye ball vents sourced from an aircraft recovery/salvage company 12 years ago. Not difficult, but you have to do a few modifications to make them work. If I recall, you need to engineer the outer rings from aluminum and drill holes for the screw pattern.
limerick offline
Aircraft: Cessna 180 Skywagon
This one looks interesting because it almost looks like you can mount it to the front of the existing can.
https://www.aircraftspruce.com/catalog/ ... elvent.php
I'm going to compare measurements this weekend.
CParker offline
Interested for the outcome on those
Good find!
Dims check out, it’s slightly smaller in ever dimension. I’m going to order one and see.
CParker offline
My solution for the vents was these from A/S. https://www.aircraftspruce.com/catalog/ ... ilver2.php
I had to replace the vent tube due to tears and discovered that Cessna had 1 1/4” tube from the wing necked down to 1” tube to the vent which of course restricts the airflow. The new vents have a 1 1/2” inlet so my son 3d printed 1.25”-1.5” funnels to run 1.5” tube to the vents. He also printed the fixture to hold the vents and fit into the original brackets. It’s an improvement in every way. The airflow is outstanding! I’m an A&P and signed it off as a minor repair.
Kras offline
Aircraft: Cessna 185 Skywagon
@cparker. how did you make out with the vent from Spruce? I have the same plastic ones and wan to consider newer ones as well.
Cameron96 offline
Aircraft: C206 Turbine
7 postsPage 1 of 1
